Pressure Drop In Gas-Solid Cyclones
Pressure Drop In Gas-Solid Cyclones Cyclone separators provide a method of removing particulate matter from gas streams at low cost and low maintenance.
In general, a cyclone consists of an upper cylindrical part referred to as the barrel and a lower conical part referred to as the cone. The gas stream enters tangentially at the top of the barrel and travels downward into the cone, forming an outer vortex. The increasing gas velocity in the outer vortex results in a centrifugal force on the particles, separating them from the gas stream. When the gas reaches the bottom of the cone, an inner vortex is created, reversing direction and exiting out the top as clean gas while the particulates fall into the dust collection chamber attached to the bottom of the cyclone.
Pressure drop calculations in gas-solid cyclones are at best empirical due to the fact that effects such as gas compression at the inlet nozzle, wall friction due to tangential flow and exit contraction of the gas leaving the cyclone are difficult to predict in terms of general friction loss equations.
Correlations for the pressure drop using empirical methods are acceptable up to Delta P = 10 in. H20. The pressure drop (Delta P) or the frictional loss is expressed in terms of the velocity head based on the cyclone inlet area. The frictional loss through cyclones is from 1 to 20 inlet velocity heads and depends on the geometric ratios.
Today's blog entry presents an Excel workbook for calculating pressure drop in a gas-solid cyclone using an empirical method. The Excel workbook uses USC units. Reference for the empirical equation used is provided in the excel workbook.
Enjoy downloading the Excel workbook and hoping to have some comments from the members of "Cheresources" on this blog entry.
Download the MS Excel Spreadsheet Here
Thanks for the post. Can you please throw some light on the efficiency calculations. Are there correlations available to estimate collection efficiency for a particular micron size of the entrained solids if the total solids in the feed is known?
LITian,
You are advised to refer Section 10.8.3 - "Centrifugal Separators (Cyclones)" in the book "Chemical Engineering Design- Vol.6" by Coulson & Richardson for estimating collection efficiencies based on the particle micron rating and provided as performance charts.
Thank you so much for sharing this!
MarcusMcguire
Sep 17 2015 01:30 AM
Dear Ankur sir
Thanks indeed...appreciate these efforts
This is very useful.
I have made efficiency excel file ..how do i share ?
Cheers
Dear Ankur sir
Cheers
Hi Marcus,
If you want to share it with the "Cheresources" community suggest you send it to "Chris Haslego" the owner of "Chereosurces" by using the personal messenger and attaching the file with your message. There is an attachment option with the PM service.
    kanakagiri
    Yesterday, 11:21 PM
    robbiejustice
    Yesterday, 04:23 PM
    Jacksparrow97
    Yesterday, 04:27 AM
    furkanarya
    Yesterday, 12:40 AM
    dan30
    11 Mar 2025 - 15:48
    stagnaman
    11 Mar 2025 - 12:25
    FernandoEs
    11 Mar 2025 - 10:08
    anginsepoy
    11 Mar 2025 - 04:07
    JSWOO
    11 Mar 2025 - 04:03
