Photo * * * * * 3 votes
Solid-Liquid Mixing In Agitated Vessels (Just Suspended Speed)
Solid-Liquid Mixing In Agitated Vessels (Just Suspended Speed) Dear All,
Solid suspension and dispersion in a liquid is an important operation carried out in mixing systems. The primary objective of solid-liquid mixing is to create and maintain a solid-liquid slurry, and to promote and enhance the rate of mass transfer between the solid and liquid phases. Such processes are typically carried out in mechanically agitated vessels and reactors. In agitated vessels, the degree of solids suspension is generally classified into three levels: on-bottom motion, complete off-bottom suspension, and uniform suspension. Refer the sketch below. For many applications, it is often important just to provide enough agitation to completely suspend the solids off the tank bottom. Below this off-bottom particle suspension state, the total solid-liquid interfacial surface area is not completely or efficiently utilized. Therefore, it is important to be able to determine the impeller agitation speed, Njs, at which the just suspended state is achieved by the particles.
Correlation for Just Suspended Speed:
Njs = minimum impeller speed to just suspended solid particles in vessel, rps
S = Zwietering constant
ν = Kinematic viscosity of the liquid, m2/s
gc = gravitational constant = 9.81 m/s2
ρs = denisty of solid particle, kg/m3
ρl = denisty of liquid, kg/m3
X = mass ratio of suspended solids to liquid or solid loading'=kg of solids / 100 kg of liquid
D = Impeller diameter, m
Table for Zwietering Constant (S):
Snapshot of an Example Problem in Excel:
This concludes today's blog entry. Would to receive comments from the learned members of "Chereosurces"
It is a very helpful content as I am designing a preparation and storage tank equipped with an agitator to keep the solids suspended in water. However the particle size is unknown but I will have its sieve analysis done soon. Could you please share the calculation sheet so that I may be able to calculate Kinematic viscosity and Njs as soon as possible?
Best Regards
Faraz Shamsey
madan023@gmail.com
May 08 2016 09:10 AM
This is very informative content.Can you please provide the Zwietering Constant for the plain bottom tanks (reactors).Please share the calculation sheet so that I may be able to calculate Kinematic viscosity and Njs of my tanks.
Hi ankur,
thanks to share this with us.
I have a question. I need to calculate the needed torque for the Impeller. Is it simply achieved by the T=r.V formulation? it means just multiply the speed of impeller to its radius?
regards
Hi ankur,
regards
Shakila,
Have a look at eqn (2) in the link below:
http://turbolab.tamu...proc/P19/17.pdf
HI Ankur,
Thank you vary much for your reply. It was so helpful.
Regards
shakila
very helpful..Thanks
Hi Ankur,
I came across your entry as I am looking into calculating the just-suspended mixing speed in agitated vessels. I tried to replicate your calculation but get a value of 3.76 rps for Njs. I wonder what I am missing. I checked the units and they all cancel out fine. Can you share the Excel file please? Thanks, Karsten
Helpful calculations. But could you please explain how Njs depends on scale of manufacturing and liquid height inside the reactor?
According to the given formula, Njs would be same for a given impeller irrespective of batch size and % volume of reaction mass.
Hi ankur,
regards
Hi Shakila21,
                    You can get the value of torque by multiplying the radius and force applied at a given RPM. But one needs to calculate Njs, P/V, Nre kind of parameters w.r.to lab scale to ensure the given RPM would be sufficient.
Santosh Neralla
Nov 03 2021 04:50 AM
Hi Ankur,
Can you please share the Zwietering constant values for Gas induction turbine agitator.
Hi ankur,
regards
Shakila,
 Hi Arkur,
X=wieght of solid/Weight of water ?
i couldnt understand.
Could you explain  it with a little bit example
Hi Ankur,
Hi Ankur,
I came across this entry again and I am still not able to replicate your sample calculation below. I get 3.76 rps vs the 0.95 rps in your image. Any input would be greatly appreciated. Karsten
    jango
    Today, 10:03 AM
    Andy M
    Today, 05:15 AM
    Santoshp9
    Today, 04:30 AM
    Yashman
    18 Jan 2026 - 10:41
    Mahmoud.Abdelrhman1993
    16 Jan 2026 - 14:26
    samuelonyewuenyi@gmail.com
    16 Jan 2026 - 07:46
    Jawahar_G
    16 Jan 2026 - 01:34
    huy.tranpetrochem
    15 Jan 2026 - 19:47
    soojungjin
    15 Jan 2026 - 17:25
