Minimum Siphoning Seal Leg Height
#1 deltaChe
deltaChe
  • 153 posts
Posted 06 October 2011 - 09:44 AM
Dear Sir/Madam
Sorry to bother you this trivial. The condensate form in these three horizontal condensers and drained directly to the storage tank.
The seal leg has to be set up to prevent the siphoning of liquid from the seal loop.
How can I determine the minimum height of the seal leg for these three condensers.
I used the following formula, the pressure difference between the tank and condenser
and neglect the pipe head loss.
The minimun height I got seems not meet with the height marked in the P&ID.
Please kindly informed me any paper or book on this issue or point me any thing wrong in this issue.
Hmin=P1-P2*10.2/sg - h(pipe loss)
Hmin= the minimum seal leg height
P1,P2 = 10^5 pa
sg = process fluid specific gravity = 1.3
Really appreciate your help, and thank you very much.
#2 katmar
katmar
  • 687 posts
Posted 06 October 2011 - 10:27 AM
I agree with your formula (except for the missing brackets). It should be
Hmin = (P1-P2) * 10.2 / sg - h(pipe loss)
This shows that the heights on the diagram are too small if the SG is 1.3
An important note is that to avoid siphoning the seals dry when flow is established the piping must be made self venting, or else there must be siphon breaks connecting the top of each seal leg to the outlet of condenser C.
#3 breizh
  • 6,714 posts
Posted 07 October 2011 - 12:43 AM
To support your query .
http://www.graham-mf...eID=48&catID=17
#4 deltaChe
deltaChe
  • 153 posts
Posted 10 October 2011 - 06:48 AM
Dear Mr. Breizh
Thank you very much for your information. The attached you post is for vaccum condensation, but
in my case is not.
And, I doubt the formual I wrote Hmin = (P1-P2) * 10.2 / sg - h(pipe loss)
is not rignt and it seems to me that P1 + H*g/10.2 - h(pipe loss) = P2. Please share any comment if you have.
Thank you very much.
#5 breizh
  • 6,714 posts
Posted 10 October 2011 - 07:37 AM
(P1-P2 ) / (Ro*g) = H min
H should be Hmin + head loss in the line
Ro= 1300 kg/m3; g =9.81 SI ;H m ; P1-P2 = pascal
Similar to what Harvey wrote .
Edited by breizh, 10 October 2011 - 06:29 PM.
