Category: | Chemistry Basics |
Question: | How many grams per liter would there be in a 0.35 N (Normality) Citric acid solution? |
Keywords: | normal,normality,calculation,citric,acid,molecular,weight, |
Answer: | The normality of a solution is the number of gram-equivalent weights of the dissolved substance per liter of solution. The gram-equivalent weight of the dissolved substance is the molecular weight of the dissolved substance divided by the hydrogen equivalent of the dissolved substance. Citric acid has a molecular weight of 192.12 and it contains three hydrogen equivalents (i.e., three COOH groups). Thus, the gram equivalent weight of the citric acid dissolved in water is 192.12/3 = 64.04 grams. And therefore 0.35 Normal citric acid would have (0.35)(64.4) = 22.41 grams of citric acid per liter of solution. |
