"Estimate Costs of Heat Exchangers and Storage Tanks via Correlations" by Armando B. Corripio, Katherine S. Chrien, and Lawrence B. Evans, Chemical Engineering magazine January 25, 1982.
There is a bunch of equations and it took some time to program it in excel but ultimately it was done.
Let us get down to the equations:
Base Cost for CS Floating-Head, 700 kPag (100 psig) exchanger
SI Units
CB = EXP(8.202 + 0.01506*lnA + 0.06811*(lnA)2)
CB = Base Cost of the HE, USD
A = Heat Transfer Area in m2
Lower Limit: 14 m2; Upper Limit: 1100 m2
Exchanger-type cost factor, FD
Fixed Head:
FD = EXP(-0.9003 + 0.0906*lnA)
Kettle Reboiler:
FD = 1.35
U-Tube:
FD = EXP(-0.7844 + 0.0830*lnA)
FD = Exchanger-type cost factor
Design-pressure cost factor, FP
700-2100 kPag:
FP = 0.8955 + 0.04981*lnA
2100-4200 kPag:
FP = 1.2002 + 0.07140*lnA
4200-6200 kPag:
FP = 1.4272 + 0.12088*lnA
FP = Design-pressure cost factor
Material-of-Construction Cost Factor, FM
SS316:
FM =1.4144 + 0.23296*lnA
SS304:
FM =1.1991 + 0.15984*lnA
SS347:
FM =1.1388 + 0.22186*lnA
Nickel 200:
FM =2.9553 + 0.60859*lnA
Monel 400:
FM =2.3296 + 0.43377*lnA
Inconel 600:
FM =2.4103 + 0.50764*lnA
Incoloy 825:
FM =2.3665 + 0.49706*lnA
Titanium:
FM =2.5617 + 0.42913*lnA
Hastelloy:
FM =3.7614 + 1.51774*lnA
FM = Material-of-construction cost factor
Heat-Exchanger Cost , CE
CE = CB*FB*FD*FM
CE = Heat Exchanger Cost, USD
USC Units
CB = EXP(8.551 - 0.30863*lnA + 0.06811*(lnA)2)
A = Heat Transfer Area in ft2
Lower Limit: 150 ft2; Upper Limit: 12000 ft2
Fixed Head:
FD = EXP(-1.1156 + 0.0906*lnA)
Kettle Reboiler:
FD = 1.35
U-Tube:
FD = EXP(-0.9816 + 0.0830*lnA)
100-300 psig:
FP = 0.7771 + 0.04981*lnA
300-600 psig:
FP = 1.0305 + 0.07140*lnA
600-900 psig:
FP = 1.14 + 0.12088*lnA
SS316:
FM =0.8608 + 0.23296*lnA
SS304:
FM =0.8193 + 0.15984*lnA
SS347:
FM =0.6116 + 0.22186*lnA
Nickel 200:
FM =1.5092 + 0.60859*lnA
Monel 400:
FM =1.2989 + 0.43377*lnA
Inconel 600:
FM =1.2040 + 0.50764*lnA
Incoloy 825:
FM =1.1854 + 0.49706*lnA
Titanium:
FM =1.5420 + 0.42913*lnA
Hastelloy:
FM =0.1549 + 1.51774*lnA
CE = CB*FB*FD*FM
Updated Heat Exchanger Cost
CE(updated) = (CI(calculation yr) / CI(base yr)) * CE
CI(calculation yr) = cost Index for the calculation year &
CI(base yr) = cost index for the base year
Notes:
1. As an example, if you are trying to calculate the cost of the exchanger for the year 2010, the most probable updated cost would be based on a ratio of the cost index for the year 2010 to the cost index for a base year of 2005. It is not recommended to use a base cost index more than 5 years older than the cost index for the calculated year.
2. The cost index ratio is subjective in nature and readers are exercised caution in determining the "Cost Index Ratio" for calculating the updated equipment cost.
Readers and Members of "Cheresources", this is it for today's blog entry. Would welcome comments from all of you on the subject matter.
