Heat Capacity Ratio, γ = Cp / Cv ------------- (1)
For an ideal gas,
Cp - Cv = R ----- (2)
or
Cv = Cp - R ------ (3)
Substituting (3) in (1) gives:
γ = Cp / (Cp - R) -------- (4)
γ = heat capacity ratio for an ideal gas, dimensionless
Cp = Specific heat or heat capacity at constant pressure, kJ / kmol-K
Cv = Specific heat or heat capacity at constant volume, kJ / kmol-K
R = Universal Gas constant expressed in energy units = 8.31447
If heat capacity or specific heat is provided in units of kJ / kg-K equation (4) gets modified as follows:
γ = Cp / (Cp - (R / MW)) --------- (5)
MW = molecular weight of the compound
Wikipedia provides the following definition for the heat capacity ratio at the following link http://en.wikipedia...._capacity_ratio
The heat capacity ratio or adiabatic index or ratio of specific heats is the ratio of the heat capacity at constant pressure (Cp) to the heat capacity at constant volume (Cv). It is sometimes also known as the "isentropic expansion factor" and is denoted by γ (gamma) (for ideal gas) or κ (kappa)(isentropic exponent, for real gas).
Today's blog entry provides a spreadsheet compilation of the "κ" values for pure compounds or components at various conditions of pressure and temperature using the simulator Aspen HYSYS Version 7.3 and is mainly intended for those who do not have access to process simulators such as HYSYS. The data has been compiled using the "Peng-Robinson" equation of state (EOS) which is one of the most preferred EOS when dealing with hydrocarbons in the oil & gas industry. "κ" values for non-hydrocarbons such as CO2, H2S, N2 and Dry Air have also been provided using the same "Peng-Robinson" EOS.
Some odd or deviant values for "κ" have been observed at high pressures and temperatures while compiling the data from HYSYS. The same have been highlighted in yellow and corresponding ideal gas heat capacity ratios in brackets have been provided for these odd or deviant "κ" values.
When dealing with a gas mixture of pure components the law of proportions may be used with reasonable accuracy to estimate the "κ" values for the gas mixture at the given pressure and temperature.
κmixture = Σ(yi*κi)
κmixture = heat capacity ratio of the gas mixture
yi = mole fraction of the ith pure component
κi = heat capacity ratio of the ith pure component
This is probably the most comprehensive "κ" value compilation provided as an open source that the readers of "Cheresources" will find at real pressures and temperatures using a widely recognized process simulaton software such as HYSYS.
Hope this will be appreciated by all and I look forward to comments from the readers of my blog on this blog entry and the attached spreadsheet providing the "κ" value compilation.
you may consider also these sources which allow to calculate a number of properties including cp and cv
for properties of pure fluids there is a online calculator (based on REFPROP),
see Ankur's comment about NIST,
REFPROP includes very accurate models for pure fluids
http://webbook.nist....hemistry/fluid/
for properties of pure fluids and mixtures directly in Excel, Matlab etc.
there is a free version of Prode Properties,
http://www.prode.com/en/properties.htm
Prode Properties includes several EOS as Peng Robinson, Soave Redlich Kwong etc.
which give values close to Ankur's results
