Pipeline Pig Launchers And Pig Receivers - Design Codes
Pipeline Pig Launchers And Pig Receivers - Design Codes Dear All,
After a long hiatus I am back on my blog. That the blog has crossed a milestone of 1.5 million views is a huge encouragement and I wish to thank the readers of my blog for such an overwhelming response.
Pig Launchers and Pig Receivers have been discussed many times on "Cheresources". However, I understood that there exists a confusion regarding the design codes to be applied for pig launchers / receivers. Today's blog entry tries to explain the design codes related to them and some rationale for them.
Older designs of pig launchers / receivers were based on the ASME Section VIII Div. 1 pressure vessel code. While these designs still exist and work, the modern design approach is to design them according to the connected pipeline or pipe code.
For fresh engineers new to piping / pipeline standards and codes, the following piping / pipeline codes and standards are followed almost universally. Some countries have developed their own standards which are also mentioned below:
1. ASME B31.3: which governs the design of process piping (code) (USA)
2. ASME B31.4 which governs the design of liquid pipelines(code) (USA)
3. ASME B31.8 which governs the design of gas pipelines (code) (USA)
4. ISO 13623:2009: Petroleum and natural gas industries - Pipeline transportation systems (standard)
5. BS EN 14161:2011: Petroleum and natural gas industries - Pipeline transportation systems (MODIFIED version of ISO 13623:2009) (standard) (European)
6. ISO 13703:2000: Petroleum and natural gas industries - Design and installation of piping systems on offshore production platforms (standard)
7. PD 8010-1:2015: Steel Pipeline on Land (code) (European)
8. PD 8010-2:2015: Subsea Pipelines (code) (European)
9. CSA Z662:2015: Oil and gas pipeline systems (standard) (Canadian)
API RP 14E: Recommended Practice for Design and Installation of Offshore Production Platform Piping Systems is a 1991 recommended practice and has not undergone a revision since 1991.
Among the aforementioned codes / standards the ASME codes are quite popular for pipeline / piping design.
Hence a pipeline designed as per ASME B31.4 should have a launcher / receiver designed as per the same code and a pipeline designed as per ASME B31.8 would have launcher / receiver as per the same code. In a rare case when a pipeline is designed as per ASME B31.3, this would apply for the launcher / receiver as well.
Designing a pig launcher / receiver as per PV code ASME Section VIII Div.1 does not make economic sense. Generally, given the same pipeline design parameters, a pig trap designed from ASME B31.3 will tend to be costlier than for one designed from ASME B31.4 or B31.8 because of the difference in material grades and thicknesses. In addition, a pig trap designed from ASME Section VIII Div.1 will tend to be more expensive than one designed from ASME B31.3 for the same reasons.
Normally a pig launcher / receiver for "liquid pipelines" which is designed as per pipeline code is provided a thermal expansion relief valve (TRV). This is to ensure its protection from overpressure due to thermal expansion of trapped liquid. For gas or two-phase fluid pipelines TRVs are not required.
Designing the launcher / receiver relief valve for external fire case is impractical although theoretically possible. In practice pigging is an intermittent operation and well planned and monitored. Before and after pigging operations it is ensured that the launcher and receiver are drained / vented to prevent any residual fluid inside. If a fire effects an empty launcher / receiver, the launcher / receiver will rupture even before the PSV designed for fire case pops at the set pressure. So practically it does not make a sense to have a PSV for fire case. Refer the link below for a very enlightening discussion on PSV on launcher / receiver. Specifically the post by don1980
http://www.eng-tips.....cfm?qid=360185
One of the reasons that engineers consider a PSV for fire case is because the pig launcher / receiver is designed as per pressure vessel code. If it were to be designed as per pipeline code then at the most for a liquid system launcher / receiver a TRV (for thermal expansion) may be provided which does not require any sizing calculations and providing a conventional 3/4 x 1" or 1"x 1-1/2" PSV would suffice. For single-phase gas or 2-phase fluid no PSV would be required.
Quick note from the admin: You can download the MS Excel workbook that accompanies this blog entry in the File Library.
That is all for today's blog entry. Look forward to comments and observations from the readers of my blog.
Sir, good explanation.
Pig signaller will be in the piping design pig launcher  or ASME design standards
All launchers and receivers have quick opening closures for inserting / removing  pigs. The pipeline code ASME B31.4 gives general guidelines about such closures. It also mentions that the safety locking device for the closure shall be designed in compliance with ASME Section VIII Div. 1 UG 35(B).
Additionally closure heads (flat, conical, ellipsoid, or spherical) must be designed to ASME Section VIII Div. 1.
Clause 404.7 of ASME B31.4 -2009 provides information related to closures.
Good summary Ankur, few years ago I use to work for slurry pipeline company and then there use to be dedicated code for slurry pipeline B31.11 which recently got merged in B31.4.
trahifarid01
Mar 14 2017 07:51 AM
Please how you calculate the speed of the pig in the pipe with tow phase ( gas and oil)???
giasarlveladze
Mar 19 2017 05:52 PM
is it mandatory requirement for Pig Receiver to have balance line?
I would think so, since the balance line allows filling and pressurization of the barrel on both sides of the pig at the same time. This is to prevent a pig which is ready to be launched from either moving forward and thereby hitting and possibly damaging the pig trap valve, or backwards and losing the seal in the reducer. To ensure this, the balance line, branching off from the kicker line, shall be connected to the minor barrel as close as possible to the pig trap valve.
Thanks. Can we locate TRV of pig launcher away from launcher, on pipe rack? so that discharge pipe is sloped to flare header.
Do you want to connect a TRV outlet (liquid discharge) to flare header???
I would never do that.
Hi good-day, I was wondering if anyone knows any requirements for balance line Nominal Size for 24 inch pig traps?
Books or credible sources will be appreciated. Thank you.
Great summery!
Could you please help me about sizing of kicker/bypass lines of launchers and receivers?
Hello, I strongly recommend you guys take a look at this quick opening closure website http://www.rxclosure.com/If you are into pig launcher receiver, you may be interested with ERGIL's RX bayonet type closure
    Today, 09:32 PM
    Today, 05:49 PM
    Today, 10:01 AM
    Today, 09:01 AM
    Hasanrif
    Today, 03:56 AM
    wolf_0605
    Today, 02:38 AM
    Yesterday, 12:10 PM
    Yesterday, 08:26 AM
    rcalaforrall
    22 Apr 2025 - 09:56
