Hello
I'm given a gas at a certain T,P and flowrate in kg-mol/hour
I must convert this to m3/hour
I think :
kgmol/hour * (RT/P) where RT/P = V/n = m3/kmol
would give me the correct units.
Is this correct ? are kmol = kgmol ?
Thanks!
Converting From Kg-mol/hour To M3/hour
Started by Guest_Guest_*, Feb 06 2005 10:13 AM
Guest_Guest_*
Posted 06 February 2005 - 10:13 AM
Posted 06 February 2005 - 03:37 PM
For any ideal gas, 1 kg-mol = 22.414 m3 at 0 °C and 1 atmosphere. Thus:
(Equation 1) m3/hr at 0 °C and 1 atmosphere = (22.414) ( kg-mol/hr )
To convert m3/hr at 0 °C and 1 atmosphere to m3/hr at any other T and P, use:
(Equation 2) P1V1/T1 = P2V2/T2
In using Equation 2, be sure to use absolute pressures and absolute temperatures (°K or °R). In some cases where there is a large difference between conditions 1 and 2, you may need to use compressibility factors (Z) in Equation 2. Thus:
(Equation 3) P1V1/(Z1T1) = P2V2/(Z2T2)
Guest_Guest_*
Posted 06 February 2005 - 10:04 PM
QUOTE (Guest @ Feb 6 2005, 10:13 AM)
Hello
I think :
Thanks!
I think :
Thanks!
Just to add a little to 'are kmol = kgmol'......
That is correct if you are working in SI units - all you are saying is that you are measuring molecular weights in kg/kmol.
You can also find lb-moles.
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
Converting A Static Simulation To Dynamic SimulationStarted by Guest_tomr91_* , 26 Feb 2025 |
Converting Pigment Into DyeStarted by Guest_zwandy_* , 09 Oct 2016 |
Converting Gas Volume From Liter To Cubic MeterStarted by Guest_Krish117_* , 17 Jul 2017 |
Converting Non-Vfd Motor To VfdStarted by Guest_colt16_* , 23 Mar 2017 |
