How To Convert Astm D86 To Tbp?
Started by liuzp308, Mar 15 2010 07:08 AM
7 replies to this topic
Posted 15 March 2010 - 07:08 AM
How to convert ASTM D86 to TBP?
Posted 15 March 2010 - 09:38 AM
Check out this link for an old post. Could provide you some starting point.
http://www.cheresour...__1
Ankur
Posted 16 March 2010 - 08:43 PM
Hi Liuz
About your inquire:
Transform ASTM D 86 distillation cuts to ASTM 2892 (TBP) light cuts
The results of ASTM D 86 distillations can be converted into an atmospheric ASTM 2892 TBP by using an equation equivalent proposed by Riazi and published by the API
Equation 1: T* = aTb
With:
T* = Temperature of TBP test [ºK]
T = Temperature distillation D 86 [ºK]
a, b = Constants depending on the fraction distilled.
Application Example:
Distillation ASTM D86 to TBP (Riazi Method)
Volume % distilled Coefficient a Coefficient b Temperature D86 ºC Temperature TBP ºC
0 0,9177 1,0019 36,5 14,1
10 0,5564 1,0900 54,1 33,4
30 0,7617 1,0425 76,9 68,9
50 0,9013 1,0176 101,5 101,6
70 0,8821 1,0226 131,0 135,1
90 0,9552 1,0110 171,0 180,5
95 0,8177 1,0355 186,5 194,1
The accuracy of method depends on the smoothness of curve. Errors affect the points in the low % distilled ranges. Average error is in order of 5 °C for smooth curve.
Wauquier pp 98-104.
Transformation of atmospheric TBP curve to ASTM D 86
API recommends a relationship established by Riazi (1982)
Equation 2: T* = aTb
With:
T = Temperature TBP [K]
T* = Temperature of ASTM D 86 [K]
a, b = Transformation Coefficients (See application example)
Distillation TBP to ASTM D86. Table 4.16a Wauquier
Volume % distilled Coefficient a Coefficient b Temperature TBP ºC Temperature D86 ºC
0 1,08947 0,99810 14,1 36,5
10 1,71243 0,91743 33,4 54,1
30 1,29838 0,95923 68,9 76,9
50 1,10755 0,98270 101,6 101,5
70 1,13047 0,97790 135,1 131,0
90 1,04643 0,98912 180,5 171,0
95 1,21455 0,96572 194,1 186,5
Source:
Petroleum Refining Volume 1: Crude oil Petroleum Products,”by Jean Pierre Wauquier. Institut Francais du Pétrole. Editions Technip. pp 98-104.
The application examples in Excel file I will send you attached here.
I think this information will be useful for you.
Good luck.
About your inquire:
With:
Wauquier pp 98-104.
With:
Source:
Good luck.
Edited by Profe, 17 March 2010 - 02:49 PM.
Posted 17 March 2010 - 02:55 PM
Hi Liuz
That I said before, attached you find the Word and Excel files about this subject How To Convert Astm D86 To Tbp.
Good luck.
Good luck.
Posted 19 March 2010 - 05:46 AM
I will suggest you should use Edmister graphs to conver D86 to TBP. These curves are avalibale in many petroleum processing books as well as in Petroleum thermodynamic by Edminster
Posted 22 March 2010 - 03:08 PM
Hi Luiz.
According with the Suhas suggestion, attached is the copy of Edmister curve in format JPG for this purpose. The source is the Perry and Green "Perry's Chemical Engineers' Handbook" by McGraw-Hill Companies. P. 13-89 figure 13-86.
Is your choice select the best method that fits your needs or verify the source.
I think that information will be useful.
Good luck.
Good luck.
Edited by Profe, 22 March 2010 - 03:11 PM.
Posted 12 April 2010 - 05:27 PM
Use the API Technical Data Book, the best source in case you want to do any distillation interconversion. Its available at www.epcon.com
AJ
Posted 29 September 2011 - 05:00 PM
hi
have anyone pdf format of Edmister book?
Calculate Mabp,wabp,cabp And Meabp From Distillation Astm D86 ResultsStarted by Guest_barks123_* , 30 Apr 2024 |
![]() Astm 2887 Vs Astm D86Started by Guest_barks123_* , 15 Mar 2024 |
![]() ![]() How To Convert Gas Mixture From Mole% To Mass%Started by Guest_chemtoli_* , 12 Mar 2023 |
Convert Nm3/hr Air To Nm3/hr NitrogenStarted by Guest_princessme_* , 09 Apr 2017 |
![]() How To Convert Kvs-Value For Water To Kvs For Gas?Started by Guest_Falko_* , 12 Jan 2022 |
