Vapour Pressure Of Hydrogen
#1 Guest_chrisp_*
Guest_chrisp_*
  • guestGuests
Posted 09 February 2005 - 04:43 PM
Hello, I am finding it extremly difficult to find antoine equation coefficients for Hydrogen gas. I have consulted perry's and other similar text books and nist.gov. Do they actually exist for hydrogen ? Thank you.
#2 mbeychok
mbeychok
  • 364 posts
Posted 09 February 2005 - 06:32 PM
Chrisp:
Page D-212 of the "Handbook of Chemistry and Physics" (56th Edition) has a tabulation of hydrogen vapor pressures that covers the temperature range of 13.8 °K to 32.98 °K which corresponds to a vapor pressure range of 0.069 atmospheres to 12.76 atmospheres.
If that is the range you are interested in, then you could use linear regression of that data to obtain a set of Antoine constants.
#3 MrShorty
MrShorty
  • 517 posts
Posted 09 February 2005 - 09:17 PM
Any reason you need Antoine constants versus other vapor pressure equation parameters? It's generally accepted that the Antoine equation isn't suitable above ~2 atm, where the above referenced data set extends to ~13 atmospheres. An Antoine correlation would be limited to the data between the melting point and 2 atm (a range of ~10 K), where a more robust equation could get you from the melting point to the critical point (~20 K span). It depends on what temperature range you need the vapor pressure for.
#4 Guest_Guest_*
Guest_Guest_*
  • guestGuests
Posted 10 February 2005 - 08:05 AM
Thank you for your kind replies. Interested in Antoine because I'm assuming ideal gas behaviour at pressures less than 2 atm.
#5 gvdlans
gvdlans
  • 619 posts
Posted 10 February 2005 - 10:33 AM
Antoine Vapor Pressure Equation: ln(Pvap) = A-B/(T+C)
Pvap is vapor pressure in mmHg, T is temperature in Kelvin
A=13.633
B=164.90
C=3.19
Valid between T= 14 K and T=25 K
Taken from Coulson and Richardson's Chemical Engineering, Volume 6, 2nd edition, Appendix D.
Same parameters can be found in the Fysical Properties Spreadsheet that can be downloaded from http://www.cheresources.com/data.xls
It should not have been "extremely difficult" to find this?
