Reflux In Distillation Columns
#1 Guest_zili_*
Guest_zili_*
  • guestGuests
Posted 14 February 2005 - 12:54 AM
Hi!
May I know what is the purpose of reflux in the distillation column? Is it to provide contacting liquid for the vapour? If it is true, why must there be contacting liquid?
Thanks!
#2 siretb
siretb
    ChE Jedi
  • 304 posts
Posted 14 February 2005 - 04:36 AM
Well, it has do to with the very basics of distillation and chemical engineering. Please refer to a book.
You may view reflux as a plain requisite for separation. If , for the sake of explanation, we assume there is almost no reflux, even if the liquid is in equilibrium with the vapors, because the amount of liquid is almost zero, the vapor composition will not change from tray to tray. Reflux is , in a way, a stream that will absorb the composition change in the vapor. This explains, why, for a given separation there is a minimum reflux.
Of course, in addition to that, the technology we use calls for a minimum wetting rate, so in the upper part of a column (above the last feed) , reflux is needed.
#3 gvdlans
gvdlans
  • 619 posts
Posted 14 February 2005 - 04:45 AM
Zili,
You posted many questions lately on distillation columns, some of which are indeed quite basic. I agree with Siretb that it may be a good idea for you to buy or borrow some good books on the subject. I can recommend H.Z. Kister "Distillation Design" New York [etc.] : McGraw-Hill, 1989. - XIII, 710 p. ISBN: 0-07-034909-6.
#4 Guest_zili_*
Guest_zili_*
  • guestGuests
Posted 14 February 2005 - 04:54 AM
Sorry that I posted so many questions.
I tried to look up books like "Perry's chemical engineering handbook" and "separation process principles" regarding reflux but none gave me an explanation on why we need reflux. They at most mentioned what is reflux and how we calculate reflux ratio.
Thanks for the recommended book. I'll go and look it up.
#5 niallmacdowell
niallmacdowell
  • 28 posts
Posted 11 May 2005 - 08:41 AM
Zili,
one book that I feel explains the necessity for a reflux in a distillation column is McCabe, Smith & Harriott's Unit Operations of Chemical Engineering.
Basically, the reason you use reflux/rectification in distillation is to get a purer distillate. Without reflux, your top/rectification section of your column is just a piece of pipe. What happens is that the LIQUID that is refluxed is rich in the desired top product. It is contacted with the VAPOUR that is rising, which contains some of (for binary distillation) both of the top and bottoms products. As the top product will have a lower bp that the bottoms, upon contacting the vpr stream, some of the reflux will vapourise, and at the same time some of the bottoms product will condense, and fall back down the column. See that reflux is vital to the act of separation, mechanical operating considerations aside.
Niall
