I am having some trouble designing a quench tower... actually, i am not sure how to start it. Should I consider it like an absorber tower? Can I simulate it in ASPEN PLUS like Radfrac, to predict the amount of water? what about NUT and HUT?
the goal is to exchange heat with a stream gas coming from a reactor, from 230 C to 90 C, at 19 bar... then, the water vapor in the stream will condensate and also some co2 will be scrubbed, even tough its not the objective.
ah, just one more thing... can i use metal packing ( steel carbon), in a absorber tower with gasoline and glp, at 50 C? I thinks theres no problem right, since gasoline is not corrosive and metal is the cheapest option
thanks folks
