Turbo-Expander Control
Posted 01 May 2010 - 04:00 AM
Please provide internet sites for reference if any.
Posted 01 May 2010 - 06:03 AM
I am trying to select the adequate control of two turbo-expander for natural gas working in parallel. Anybody knows the different type of controls? and their advantages/disadvantages ?
I'll be dealing with it soon bacause I have to analyse offer for such turbo expander. I'll try to give you some basic concepts when I'm back in the office. There is a very thick book called "Pump user handbook" - many authors. I belive something may be found there. Normally piping and instrumentation diagram (P&ID) for such compressor, where you can see compressor stages, intercoolers, compressor and turbine control scheme, is up to supplier. Such P&ID is not so easy and full of controls, interlocks etc...but if it's just school work maybe could be simpyfied.
Edited by wojtar, 01 May 2010 - 06:05 AM.
Posted 01 May 2010 - 07:59 AM
Did you try Google ?
This US patent may give you some indication
http://www.freepaten...om/4281970.html
Hope this helps
Posted 02 May 2010 - 05:18 AM
The Turboexpander-compressor discharge pressure signal is transmitted to the Master Pressure Controller, and the MPC then makes necessary adjustments to:
a.) Expander guide vane position,
b.) J-T valve position,
c.) Anti-surge control for the compressor side of the expander/compressor unit.
Basically, this is the simplified control narrative for all turboexpander facilities I came across. Not sure if your question refers to controlling both expanders at the same time (2x50%) or what possible control schemes we have in general for turboexpanders. You may expand a little bit on that.
Edited by Zauberberg, 02 May 2010 - 05:19 AM.
Posted 02 May 2010 - 07:17 AM
The expander speed is established by the manufacturer, given the process conditions. For maximum efficiency, the expander manufacturer determines the wheel diameter and specific speed. As plant operating conditions change, the expander speed may change. Fig. 13-75 shows the change in efficiency as a function of change in design flow rate.
Gas entering the expander is directed by adjustable nozzles into the impeller. About one-half of the pressure drop across the expander takes place in the nozzles, imparting kinetic energy to the gas which is converted to shaft horsepower by the expander wheel. Pressure reductions are normally limited to 3-4 ratios. Greater ratios reduce expander efficiency to the extent that 2-stage expansion may be advisable.
The adjustable nozzles function as pressure control valves. A pneumatic operator takes a split range signal (3 to 9 psi) to stroke the nozzles. On increasing flow beyond the full open nozzle position, a 9 to 15 psi signal from a pressure controller opens a bypass control valve. This valve is called the J-T (Joule-Thomson) valve.
Posted 08 May 2010 - 11:27 AM
1- Identifying the different type of controls for 2X 50% turbo-expanders.
From Zauberberg answer I can see that the expander can be controlled based on the pressure at the turbo-expander discharge.
I have also found that it can be controlled based on the pressure at the expander inlet, ect...
Is it only the type of controls used?
2- How to select among them?
Thanks again
Posted 08 May 2010 - 01:01 PM
On the other hand, some NGL recovery plants (Ortloff's SCORE for example) control the pressure downstream of expander, in the De-C2 tower. Once when you know what do you want to control, it's relatively easy to setup the control scheme.
Best regards,
Surge Analysis-Control LogicsStarted by Guest_stu_* , 30 Dec 2024 |
![]() Pump Dischrge Control Valve SizingStarted by Guest_Lyne_* , 04 Jun 2024 |
![]() ![]() Ahu Chilled Water Hot Water Control And FunctioningStarted by Guest_RAMSAI_* , 23 Sep 2024 |
![]() Control Valve Failure Psv SizingStarted by Guest_fmalik_* , 05 Sep 2024 |
