Coal And Gas Dual Fuel Fired Boiler
Posted 07 May 2010 - 02:29 AM
I am doing a concept phase study of feasibility of circulating fluidized bed boiler. While working, I came upon a question: whether there is any boiler which can run both on natural gas and coal?
If there is such equipment then I would like to know the manufacturers of dual fired boilers.
Nabeel
Posted 07 May 2010 - 11:14 AM
I am doing a concept phase study of feasibility of circulating fluidized bed boiler. Whilke working I came upon a question that
whether there is any boiler which can run both on natural gas and coal?. If there is such equipment then I would like to know the manufacturers of dual fired boilers.
Nabeel
Nabeel,
I know about dual oil/gas fired boilers where dual burner guns for oil/gas are interchanged for oil/gas firing.
However, a coal fired boiler has fundamentally a totally different construction. They have a stoker grate for burning pulverized coal.
It must require a very special design to have both gas firing and coal firing in the same combustion chamber. I have really no idea of such a dual coal/gas fired burner.
Posted 08 May 2010 - 03:49 AM
From historical view point, Australian alumina plant had the seasonal flexibility to shift from fuel oil to coal (1970s or 80s) depending on price. And power stations burning peat (turf) of low heating value can simultaneously burn liquid fuel to ameliorate combustion (read it, but not found in WWW). These are not examples of coal dual firing (as defined above), but indicate need of it and steps toward it. Fluidized bed coal boilers of pressurized type (slightly over atmospheric pressure) seem almost suitable to burn coal simultaneously with liquid or gas fuel, if they have not managed it already.
Above indicates future of dual firing (with coal and some other fuel) for boilers of big capacity e.g. serving power stations. Probably search can start from this point.
Edited by kkala, 08 May 2010 - 03:50 AM.
Posted 08 May 2010 - 07:20 AM
Dual fired boilers - boilers that can burn either solid fuels or liquid and gas fuels - are old technology. I say "old" because I used them and specified them. I was involved in this application when processing corn cobs, oat hulls, and even sugar cane bagasse to extract Furfural. The solid residue was always burned in boilers that had dual-fired capability. The burning of the solid fuel was either through stokers or pneumatic conveying.
Major boiler designers and contractors like Combustion Engineering in the USA did this routinely. There should be no technical problem in having one designed and built. There might be a problem in the economics. To find out more information, you should contact major boiler designers and manufacturers. You don't tell us where you are located, so you make it difficult for our members to recommend anyone you can contact.
Posted 11 May 2010 - 07:30 AM
By dual I do not mean that the boiler will use both the fuels i.e. coal and natural gas simultaneously, but these two fuels will be burned separately. This I think is achievable with separately designed burners in a single boiler. However I will contact the designers and get the information.
Posted 30 March 2011 - 12:43 PM
Here we have a solution of your problem. Our company Eco-Gen in Lahore, Pakistan is manufacturing this product which is Dual-Fuel Burner which can burn fire in ur boiler with coal. For more details, contact us:
Mr. Talib Hussain Shah
Eco-Gen
0300-8433319
And for more products info, visit: www.eco-energys.com
Product Overview:
http://rapidshare.co...FUL_SYSTEM.docx
Edited by Taimoor Ali, 30 March 2011 - 12:51 PM.
Posted 04 October 2011 - 10:59 PM
I am also looking for a coal fired burner. Currently i have a rotary furnace and i am using Natural GAs fired burner; however i need to switch from natural gas to coal gas and install a system where we produce coal gas from coal and then be able to fire this gas through a coal gas based burner into our rotary furnace.
I am new at this so if you could name exact names of suppliers and send me links then that would be appreciated
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Effect Of Continuous Blow Down To Boiler Feed WaterStarted by Guest_Dyames027_* , 21 Nov 2024 |
Sugar Impurities After Distilling Ethanol FuelStarted by Guest_vyse_* , 14 Nov 2024 |
Minimum Vapor Disengagement Area For A Kettle BoilerStarted by Guest_Engib33r_* , 17 Oct 2024 |
Low Pressure Steam BoilerStarted by Guest_Faisal Saleh_* , 07 Aug 2024 |
