Pressure Drop Across Pipe
Posted 14 May 2010 - 11:42 AM
i am trying to calculate pressure drop across pipe L=27000 m
and flow rate= 13600 m3/h
NG of density=105 kg/m3
and 60 c, p=1440 psig
D of pipe= 12 in
after calculation p drop is very large but actual pressure drop is 200 psi
Posted 14 May 2010 - 12:03 PM
hi all,
D of pipe= 12 in
Please specify your procedure for pressure drop calculation.
Posted 14 May 2010 - 12:19 PM
hi all,
D of pipe= 12 in
You are trying to calculate delta P in a pipeline for natural gas. Can you provide the composition of your natural gas composition or specific gravity of gas. Using single phase gas pipeline`equations such as AGA, Weymouth & Panhandle A/B the pressure drop can be calculated.
Posted 14 May 2010 - 03:39 PM
Posted 14 May 2010 - 11:31 PM
Screw Compressor Suction Pressure DeterminationStarted by Guest_Deicide Dunkelheit_* , 22 Jan 2025 |
