Npsha Calculation (Using Lpg)
Posted 19 May 2010 - 11:12 AM
Posted 19 May 2010 - 12:24 PM
Also, you need the vapor pressure of LPG. You can again use HYSYS. However, since LPG is stored in spheres, it is in equilibrium, so the vapor pressure and the vessel operating pressure are considered to be same and cancel out while calculating NPSHa. I am not sure on this part, so you should wait for other experienced members have to say.
Once, you have all the inputs, you can use the NPSHa equation.
Posted 20 May 2010 - 12:33 AM
Be generous with NPSHa margin, once I applied 2 ft over manufacturer's NPSHr (liq NH3 pump) but the first two impellers of the vertical pump were often sent for repair to maintenance shop.
Calculated pressure at any point of suction line (for sphere LLLL) should not go below LPG vapor pressure, to avoid (even temporary) vaporization. This is normally valid for nearly vertical suction lines; I had made a pressure - suction length diagram to check it in the case of mentioned pump.
"Propane is taken from a sphere" is not well understood; "propane" may mean LPG (composed of 70% propane in this case).
*if inert gases (e.g. N2) are dissolved, gas pressure in sphere can be a little higher than vapor pressure at suction. Temperature a bit higher at upper volume of sphere could have similar effect too. These had been observed in liq NH3 storage, but had not been considered in the NPSHa calculation (correctly judged as occasional and non conservative).
Posted 20 May 2010 - 09:19 AM
I would like to ask you something:
I have an sphere from where i`m gonna take propane 100%. Initially this sphere was designed for working with the mixture of 70% propane and 30% Butane but now is gonna work with propane (100%). With the first condition of sphere (70/30) We had a problem with pumps NPSHa...this was very negative and we had to change horizontal for vertical can pumps. Now our client wants the sphere working with the second condition (100%). How do you think this change is gonna affect calculations now..?. What do i need to take in count..?. Do you have a PROPANE PROPERTIES CHART?.
I appreciate your comment o.k....!. Thank you. (Take alook on attache png).
Posted 21 May 2010 - 03:17 PM
Similarly to what written before for LPG (70/30), propane operating pressure at liquid surface in the sphere will be same as vapor pressure at suction nozzle. So NPSHa shall be liquid static head (at LLLL)-frictional pressure drop in all the suction line (datum is suction centerline).I have an sphere from where i`m gonna take propane 100%. Initially this sphere was designed for working with the mixture of 70% propane and 30% Butane but now is gonna work with propane (100%). With the first condition of sphere (70/30) we had a problem with pumps NPSHa...this was very negative and we had to change horizontal for vertical can pumps. Now our client wants the sphere working with the second condition (100%). How do you think this change is gonna affect calculations now..?. What do i need to take in count..?. Do you have a PROPANE PROPERTIES CHART?.
Attached LPG.xls gives some data, as well as references for propane properties. Given that the vertical pumps have solved the problem of NPSH for LPG (70/30), no problem is normally anticipated for propane (changes seem minor). Nevertheless hydraulic calculations should be made to confirm this and specify any changes (e.g. in pump flow rate), as explained in LPG.xls.
Design pressure of sphere (receiving now propane) can be an issue. Pumps shown in attached PID are horizontal, understood to be vertical now.
Hcl Fumes CalculationStarted by Guest_Chemeng40_* , 16 Oct 2024 |
Hydraulic CalculationStarted by Guest_applepe_* , 06 Oct 2024 |
![]() Final Composition Calculation Of First Iteration Of Methane Steam RefoStarted by Guest_kikisapsal_* , 14 Sep 2024 |
![]() Need Help For Utility Flow Rate Calculation For A Chemical ReactorStarted by Guest_Asisr_* , 12 Sep 2024 |
