Friction Loss Calculation
#1 Mech.Engineer
Mech.Engineer
  • 24 posts
Posted 24 May 2010 - 04:55 PM
HI EVERYBODY.
I WOULD LIKE TO KNOW WHAT SECTION OF THE PIPING NET I SHOULD TAKE FOR CALCULATING FRICTION LOSS DUE TO FLOW OF PROPANE(100%).
Should i take the complete section?(SEE ATTACHED PNG),I mean, if i`m gonna calculate NPSHa in one of the pumps, should i take the "complete" section or the "L" section..?.
Can i use the same equations than those used for water..?. any reference example?.
In advance...Many thanks...!.
Edited by Mech.Engineer, 24 May 2010 - 04:57 PM.
#2 zdendacejka
zdendacejka
  • 4 posts
Posted 25 May 2010 - 02:38 AM
you have to do complete energetical evaluation of piping (look over attached image).
Posted Image
  • Compute velocities (or volume flows) in parts 1, 2, 3, 4 and symmetrical branch (2*, 3*, 4*) - equation of continuity for incompressible flow will be useful (v1*A1 = v2*A2). Remember that flow divides into two equal parts at part 5.
  • Compute friction losses in parts 1, 2, 3, 4 - Posted Image, Posted Image, Posted Image. L is length, D is diameter, v is velocity and lambda is cofficient of friction losses (some empirical equations for laminar or turbulent flow are mentioned). Efl is specific loss - you have to multiply it by for example mass flow to get concrete energy loss.
  • Then evaluate friction loss for each pump - simply sum up one half of friction loss in part 1, with parts 2, 3, 4 (or symmetrical).
Remarks:
  • In addition to friction losses there are local losses in parts 5, 6, 7, 8 - loss in elbow, piping extension / reduction...
Hope this helps...
#3 Mech.Engineer
Mech.Engineer
  • 24 posts
Posted 25 May 2010 - 07:09 AM
Thanks for your answer.
anyone else can help me...?. I would like to have another example, maybe an on line example...I would like to have several points of views...
In advance...many thanks for helping me.
#4 zdendacejka
zdendacejka
  • 4 posts
Posted 25 May 2010 - 11:10 AM
Several links:
#5 breizh
  • 6,715 posts
Posted 30 May 2010 - 05:04 AM
HI ,
Let you try PSIM , you should be able to download it for free on Internet. PSIM : pump system improvement modeling tool
it should support your query.
#6 mcgill.engineer
mcgill.engineer
  • 3 posts
Posted 01 June 2010 - 07:46 AM
Everything you need is here:
http://www.lmnoeng.c...rcyWeisbach.htm
You basically need to use Darcy Weisbach equation to get the friction losses in the pipe. H=f(L/D)(V2/2g). To get the value for the friction coefficient (f), you will have to use the Moody chart (just google it). To use the chart, you will need to calculate your Reynolds number. The other variable in the equation are V, L, and D. V=velocity=flow/crosssectional area. So you will need to split your line into sections (each of which has a constant flow and area) and calculate the velocity in each section. L will be the length of each. Finally, you will calculate H for each section and this will give you the major losses in your pipe.
You will then need to account for the minor losses for each elbow,joint,valve, etc. The equation is h=K(V2/2g) where the value of K depends on the fittings you have. You will need to sum-up all the minor losses of all the fittings. You can find the K values for fittings in the same link at the beginning of my post.
Edited by mcgill.engineer, 01 June 2010 - 07:48 AM.
