How can I calculate LHV(low heating value)?
And what is LHV value apply for?
Thank you very much.
Low Heating Value Meaning And Application
Started by deltaChe, May 30 2010 07:00 AM
Posted 30 May 2010 - 07:00 AM
Posted 10 June 2010 - 09:28 PM
LHV is the amount of heat released by combusting a specified quantity.
You can calculate from enthalpy data, heat of combustion, or from HHV data (HHV includes the heat of condensation of water in the combustion products.)
Posted 10 June 2010 - 11:34 PM
Posted 11 June 2010 - 09:53 AM
Hello everybody:
Hi hswang2, for liquid and solid fuels, the LHV in MJ/kg is calculated (with a ± 3% error) in this way:
LHV = 34,8*c + 93,8*h + 10,46*s + 6,28*n - 10,8*o - 2,5*w
where:
c = Carbon content in kg.
h = Hydrogen content in kg.
s = Sulphur content in kg.
n = Nitrogen content in kg.
o = Oxygen content in kg.
w = Water content in kg.
I hope this helps you.
where:
Posted 11 June 2010 - 10:10 AM
Posted 14 June 2010 - 05:55 AM
HHV = LHV + latent heat of vaporization of water formed during combustion
In all practical calculations of Heat Duty LHV is used as it gives energy available for heat transfer.
Heat duty corresponding to HHV is not possible to achieve in practice.
Posted 22 July 2010 - 10:39 PM
hswang2,
I posted a spreadsheet on industry professionals forum, a basic spreadsheet that can calculate LHV and HHV's based on composition of fuel mix.
Look for the forum called "two spreadsheet calculations" by ankur2601
Secondary Heating Loop For ReactorStarted by Guest_TheChemEng_* , 28 Nov 2024 |
![]() How To Arrange The Heating Coil?Started by Guest_nhuthoahuynh13_* , 17 Oct 2024 |
![]() Heating Coil In A Storage TankStarted by Guest_Noman97_* , 05 Jun 2024 |
![]() Psv Flowrate In Abnormal Heating In The Heat ExchangerStarted by Guest_Platonicus_* , 27 May 2024 |
Heating Of Natural GasStarted by Guest_kaidlut_* , 01 May 2024 |
