Dear Members
Our refinery has a Biturox Plant with an Incinerator to burn off the off gases generated from the plant. Presently there is not any waste heat recovery system. I wish to design an Waste Heat Recovery Boiler for producing MP steam of 13 kg/cm2 a pressure.
Kindly provide me some information / reference where I can find the basics of designing a waste heat boiler.
Rabindra
Note:By mistake I had posted the same in Student Forum,
Waste Heat Recovery Heat Exchanger Design
Started by rabindra, Jun 14 2010 11:38 AM
Posted 14 June 2010 - 11:38 AM
Posted 14 June 2010 - 07:47 PM
Hello Rabindra,
Posted this site in reply to the message you left on the student board and am re-posting it now that you moved the original post. Hope this resource helps.
http://www.hrsgdesign.com/design0.htm
-JT
-JT
