Sulfuric Acid Dosing Ph Calculation
Posted 29 July 2010 - 09:31 AM
In order to lower the pH, we dose with 93% sulfuric acid using an LMI metering pump.
The entire plant volume of 5200 cubic meters per day of drinking water is dosed with acid which drops the pH of the drinking water from 6.1 to 3.9. There are several pipe-elbows and an improvised static mixer downstream of the dosing point which aid in mixing the acid and water volume before the pH sensor can record the pH value.
What is the volume of sulfuric acid required to make this (or any) change?
Alternately, what is the volume of 50% sodium hydroxide required to bring the pH back up to 6.1 after reducing it to 3.9?
I have used some calculations using the molarity of sulfuric acid and the pH change (and its effect on hydrogen ion concentration) that I found on the internet but I don’t think the calculation was correct since it doesn’t match the real-world numbers too closely.
I'm new to this forum and I appreciate your help in advance on this one.
-Dan
Posted 29 July 2010 - 10:06 AM
Posted 29 July 2010 - 03:14 PM
Are there any other ionic species present in the system that can contribute to overall reaction chemistry? I'm surprised that you are getting significant deviations from calculated values since it is diluted system. Perhaps you can upload your calculation spreadsheet so that we can give further comments.
See attached pdf of the calculations. It was adapted from this forum: http://www.physicsfo...ad.php?t=217922
The amount of acid actually being used was on the order of 1/4 the amount calculated on that sheet. That sheet is determining the acid required to drop from 5.5 to 4.
Let me know what else I can provide.
Posted 29 July 2010 - 03:50 PM
See below:
Parts Per Million
NH4: 0
K: 8.71
Na: 113.05
Mg: 3.39
Ca: 0.85
Sr: 0.02
Ba: 0
CO3: 0
HCO3: 2.09
NO3: 0
Cl: 190.69
F: 0
SO4: 2.43
SiO2: 0.02
Boron: 1.13
CO2: 2.48
Total Disolved Solids: 327.69
That is the hypothetical makeup of the water that is being injected with 93% sulfuric acid.
Posted 30 July 2010 - 01:42 AM
It was a long time ago since I was doing pH calculations but here's a spreadsheet I made for your case. If I plug the same figures like those used in the web example you referred to, the same result is obtained. Something similar can be prepared for NaOH addition as well.
Good luck,
Posted 03 August 2010 - 08:04 AM
Hcl Fumes CalculationStarted by Guest_Chemeng40_* , 16 Oct 2024 |
![]() Equilibrium Data For Nitric Acid And WaterStarted by Guest_ksagarzazu_* , 07 Oct 2024 |
Hydraulic CalculationStarted by Guest_applepe_* , 06 Oct 2024 |
