Posted 15 August 2010 - 01:02 PM
All:
Ive taken the liberty of editing and correcting the OPs posts because I believe some of the corrected elements in the posts have given the wrong impression or communication.
I believe this is what has provoked a veteran and experienced field engineer like Zauberberg to make the comment(s) in his post. One cannot expose steam to a cryogenic wall temperature (-195.75 oC at atm. Pressure) without having the droplets of instantly condensed steam immediately freeze on the tube surface. This water ice formation continues to form and forms a barrier for further heat transfer and converts itself eventually into an iceberg. I believe the erroneously applied term, steam bath, has caused confusion.
This, in my opinion, is NOT a steam bath heater. Since I started out in the compressed gas industry, I am familiar with and have designed and used this type of vaporizer out in the field before. This is nothing more that a hot water, submerged coil heater/vaporizer. The steam is sparged into the water to heat it (the water) and NOT the LIN. The LIN only comes into contact with hot water.
This type of vaporizer is very unstable and is not recommended for use with cryogenic liquids because it requires an inordinate amount of heat energy and requires constant, steady heating and agitation (which causes water convection). It is subject to a high degree of empirical factors and experienced design. An inexperienced or bad design usually results in a frozen block of water ice and little or no vaporization.
This type of vaporizer CAN be made to work but at the expense of manual supervision and constant monitoring. This design relies basically on supplying sufficient water flow (in the form of a constant, moving film coefficient) such that it will immediately carry away cooled water and replace it with a warm water film. To do this in a static water tub that contains a submerged coil and NO mechanical agitator demands that one supply agitation and convection currents in the static water bath through other means. This is done by designing a steam sparger that essentially supplies both required heat transfer ingredients: a hot thermal fluid supply source and an agitation source (pressure differential causing expansion, turbulence, mixing, and steam condensation. This has all the potential for causing some negative effects as well: mechanical movement, noise, violent mixing, and potential stresses in what is a non-pressure vessel (a coil box or tub).
The process design is rather straight-forward. This type of vaporizer produces a saturated vapor hardly never a superheated vapor. That means that all latent heat of vaporization is furnished by the sparged steam. This is easy. However, the coil box (or tub) must be kept open, full of water, and allowed to drain the subsequently condensed steam. This is usually into an open drain system and all condensate is lost to the boiler plant.
The mechanical design is the real secret of making this operation work. The steam must be sparged and distributed underwater in such a manner that it affects the entire coil in a positive, heat transfer mode. To do this, it must cause sufficient convection currents within the static water bath such that the entire coil is kept in continuous, positive heat transfer mode without suffering from localized freezing of the surrounding water. Once the surface of the coil freezes the surrounding water, any external convection currents are terminated and heat transfer, for all practical purposes, comes to a halt. Bear in mind that any localized surface freezing of the water affects the induced convection currents produced by the sparger. When this happens, more and more water surface starts to freeze and the result is a Domino Effect. The vaporizer starts to drop in efficiency and the effect can be a collection of LIN within the coil that may be entrained out with the little vapor produced all depending on the mechanical and instrumentation design employed. Characteristically, this design relies on much empirical mechanical design know-how and only experienced and knowledgeable persons or firms should undertake the design and installation of such a device.
