Flare System
7 replies to this topic
#1 Sandy2000
Sandy2000
  • 3 posts
Posted 21 August 2010 - 01:01 AM
Dear Engineers
I have a problem in Flare system, n my project (a propylene plant) there is a limitation in high elevated equipment such as Flare stack (it is included the flame length)which could not be higher that 45meter.
as I estimated the flare height doesn’t meet the limitation so there is solution to use the ground flare but I don’t have any experience and idea to use this kind of flare.
Please tell me it is practical to use the mentioned flare and what is its pros and cons.
thank so much
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 21 August 2010 - 09:11 AM
Sandy,
Mentioned below are some points related to ground flares which I could put together in company standard I prepared for a middle-east O&G company:
Ground Flares
A ground flare is a fully shielded device that produces essentially no ground level radiation.
1. Following is the justification for providing ground flares :
a. To eliminate or reduce radiant heat to nearby equipment or work areas.
b. To reduce noise in the immediate vicinity.
c. To make the flare flame less obvious for community relations
d. To potentially achieve improved emissions.
2. Ground flares use multiple burner tips arranged on staged burners, ensuring smokeless burning under all flow conditions.
3. Ground flares generally have higher total costs compared to an elevated flare for the same load.
4.Ground flares have lower operation costs and better turndown (generally 0 to 100%).
Hope this helps.
#3 afi
afi
  • 7 posts
Posted 23 August 2010 - 01:09 AM
Dear Ankur;
Thanks so much for your useful answer, but I have another problem too that in case of using the Multipoint ground flare how much sterilization area is needed(is there a relation between flare load and required area ?)
and what is the limitations in using ground(enclosed) flare,
Best Regards
#4 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 23 August 2010 - 09:23 AM
Afi,
I think there is some misunderstanding in your comparison of a ground flare with an elevated flare. A ground flare is also an enclosed flare which means that there is no visible radiation from a ground flare which also means that there is no sterilization radius.
My earlier post has also mentioned that ground flares have a higher first cost compared to an elevated flare.
Hope this helps.
#5 afi
afi
  • 7 posts
Posted 25 August 2010 - 12:42 AM
Dear Ankur;
I know that the enclosed ground flare is a type of ground flares and has no sterilization area but my question is about another type of ground flare which named Multipoint(open)ground flare (as in attached file), I want to know the calculation method of this kind of flare.
thanks
#6 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 25 August 2010 - 11:06 AM
Afi,
In your attachment there is an option to provide radiation fence for the open ground flare which prevents any visible radiation.
The open flare radiation fence is made of steel with refractory lining to withstand the high temperatures.
Edited by ankur2061, 25 August 2010 - 11:16 AM.
#7 afi
afi
  • 7 posts
Posted 28 August 2010 - 06:25 AM
Thanks for your reply,
So there is no need to take sterilization radius and another question that how I can determine the number of burners, how is related to the rate of burning?
thanks
#8 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 28 August 2010 - 08:10 AM
Afi,
Number of burners for a ground flare requires specialist knowlwedge of flares. A lot of information related to flares is still empirical in nature and not in the public domain and only few vendors including:
John Zink
Flare Industries
Callidus Technologies
Hamworthy Combustion
can design ground flares. Anybody who needs to install a ground flare would contact any such reputed vendor to provide the exact configuration of the ground flare including the number of burners. Based on the basic engineeeing data for the flare provided to the vendor, the flare vendor would provide the design. I would not consider it wise for you to try and determine the number of burners based on what I have said above.
Hope this helps.
Edited by ankur2061, 28 August 2010 - 08:24 AM.
