I am unclear about the equation to estimate minimum number of trays for distillation column according to Fenske-Underwood-Gilland method. The equation is Nm = log[(dLK/bLK)(bHK/dLK)]/log (relative volatility of light key to heavy key)
where d is distillate rate and b is bottom rate (LK =Light key, HK=Heavy key)
relative volatility (a) = [(a)top(a)bottom]0.5
For my distillation column, I know only the pressure on top and bottom but I don't know the temperature. So I wonder that what temperature I should use for estimating relative volatility at the top and bottom of the column.
In my column, there is mixture of HC ranging from C2 to C4 (paraffin and olefins). The distillate is designed to obtain 99% ethylene. So my light key component is ethylene whereas heavy key is propylene.
I don't know whether I did it wrong or not. The temperature at the top is its bubble point at that pressure. On top, I assume that only ethylene 99% and propylene 1% mole. On the other hand, the temperature at the bottom is bubble point of the mixture at that pressure. At the bottom, I estimated the bubble point from every component, not only ethylene and propylene.
I'd appreciate if you could comment on my idea to calculate this one.
Thank you.
Edited by polipo, 25 August 2010 - 10:06 AM.
