The project/simulation is done is Hysys.
I need help with an assignment that I received a while ago. Basically 5 crude assays were given, with their costs per barrel, and the products that needs to be produced, and the selling price of the products (see attaced for the assignment).
Using mass balances and solver in excel I came up with the ideal mixture(optimized for maximum profit) for 90% pure streams and 100% pure streams, 2 of the 5 crudes was selected, with volume flows of:
90% Conversion
Forcados: 570 414 barrels/day
Qua Iboe: 429 586 barrels/day
100% Conversion
Forcados: 546 284 barrels/day
Qua Iboe: 453 715 barrels/day
As I don't know yet how pure I will get the streams, I took the average of the 90% and 100% conversion for the crude stream.
Now, the difficult part that I'm struggling with is seperating the crude stream into the required products using a distillation column.
There are 5 products that need to be produced, along with the light and heavy components that cannot be sold. Altogether the distillation column needs to have 7 outlet streams. Thus 7 specifications is needed.
I have tried many times to simulate the column with the component flows (defining the component flows for each outlet stream, calculated theoretically), but the column will not solve in any way.
I need some advice regarding how to approach this problem, and how to design the column, how to column should look like, and what variables I should specify.
Any info on how to design a refinery in Hysys would be appreciated.
Please read the attached assignment if you need any additional info.
Thanks!
Edited by Saidar, 31 August 2010 - 10:22 AM.
