Air Water Cyclone Separator Design
Posted 16 September 2010 - 01:19 AM
HOPE U ALL DOING WELL,
WELL NOW DAYS I AM IN TO CYCLONE SEPARATOR DESIGNING FOR AIR WATER SEPARATION.
I HAVE GONE THROUGH MANY LITERATURES AND BOOKS INCLUDING LUDWIG,I HAVE NOT FOUND SPECIFIC DESIGN GUIDLINE SPECIALY FOR GAS LIQUID OPEARATION.
DOES ANY ONE HAVE THE IDEAS ABOUT THIS?
CAN I USE THE SOLID GAS CYCLONE SEPARATOR DESIGN ( SINCE IT IS READILY AVAILABLE ) FOR GAS LIQUID SEPARATION OPTION?
THANX
PANKAJ THAKUR
Posted 16 September 2010 - 02:14 AM
http://www.chemsof.com/
Hope this helps
Posted 16 September 2010 - 10:34 AM
Here is what is mentioned in Section 10.9, Gas-Liquid Separators of Coulson & Richardson, Vol. 6:
Cyclone separators are also frequently used for gas liquid separation. They can be designed using the same methods for gas solids cyclones. The inlet velocity should be kept below 30 m/s to avoid pick-up of liquid form the cyclone surfaces.
Hope this helps.
Posted 16 September 2010 - 10:46 AM
Have a look at this additional info: http://217.174.18.60...pr/e-pr-850.pdf
Posted 16 September 2010 - 12:03 PM
A very nice spreadsheet for cyclone separator sizing and cyclone separator efficiency calculation is available at:
http://www.enq.ufsc....313/cyclone.xls
Hope this helps.
Edited by ankur2061, 16 September 2010 - 12:04 PM.
Posted 16 September 2010 - 11:00 PM
thanx a lot for helping.
Edited by thakur, 16 September 2010 - 11:01 PM.
