first of all I would like to introduce myself. I'm a chemical engineer and after many years of working as project engineer I have to do some hydraulic calculations...they are very simple but I have some doubts, sorry if they look dumbs.
The attached scheme describes the system: liquid with flow rate of 2,8 m3/h comes from a system (column+condenser)to a gravity separator (E-1). The scheme simplifies the situation in which the bottom valve is closed and the liquid exits from the top of the separator.
The plant manager asked me to verify that liquid doesn't go to vent line. My idea is calculating
pressure drop along the discharge line to the second vessel (E-2) and demonstrate (converting it to mcl from bar) that is lower than the distance DH (that is the vent height). Is it correct?
From my calculation the pressure drop will be negative (due mainly to the difference in height between the two vessels).
Thanks in advance for your help
Marco
