You take LP steam and compress it to a higher pressure steam. There is a compression ratio that limits the amount of compression you can do. Its usually somewhere around 2.1 to 2.5.
The steam produced by MVR are superheated steam and usually require some sort of desuperheater before usage in heat exchanger/evaporators.
When steam is compressed, condensate is produced. So there would be an inlet steam in the MVR and two outlets: a higher pressure steam and condensate.
My question is how can it produce condensate while pressurizing steam to superheated steam? Won't the superheated steam just vapourize the condensate?
And how do you calculate the amount of condensate produced by pressurizing steam? Just taking random numbers, 100 kg/hour of steam goes in the MVR at 90 kPa and 96.7129 C (saturated) and leaves at 180 kPa (compression ratio of 2). How much steam is leaving? How much condensate is leaving?
I found an isentropic compression calculator here: http://www.engineeri...e.com/calc4.htm
The Kappa is the compressibility factor, right? If so, I used the steam tables from Spirax Sarco, and it gave me a compressibility factor less than 1. This resulted in a decrease in temperature according to that calculator.
This is rather weird... and I'm totally confused now. =]
Edited by Limilicious, 16 October 2010 - 06:38 PM.
