Dear friends:
which factor must be considered for choosing oil or grease for pumps?
we can change oil to grease without side effects on pump health?
best regards
Grease Or Oil Lubrication For Pumps
Started by Rahimzadeh, Oct 22 2010 02:08 AM
Posted 22 October 2010 - 02:08 AM
Posted 22 October 2010 - 02:38 AM
Hi
I don't see difference as long you have a good preventive maintenance plan .
Of course you need to stick to the recommendations from the vendor ( type of lubricant,....)
Attached a paper which may help:
http://www.pump-zone...rticles/239.pdf
Hope this helps
Hope this helps
Posted 22 October 2010 - 09:26 AM
The most important factor you have to consider when deciding whether to use oil or grease lubrication on your centrifugal pumps is to heed the pump manufacurer's instructions.
You are NOT FREE to decide which lubrications system to employ on a pump. This is decided upon when the pump is being either specified or designed for the application. Of course, as the user, you are free to specify your preferences. But the manufacturer determines the ultimate lubrication method and whether your lubrication preference can be supplied.
This is only common sense since the type of bearings employed in the pump design are basically what determines the applicable type of lubrication shall be. Some bearings can tolerate either grease or oil; others demand only one type alone. The bearing design, the operating temperatures, the speeds involved, and thrust forces are only some of the many details that have to be taken into consideration during bearing selection and design.
Don't forget: You are NOT the pump expert. The manufacturer is. Therefore, it is wise to heed the manufacturer's instructions.
![]() Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
Vibration Of The Pump (Reciprocating Pumps / Plunger Pumps)Started by Guest_vsedhuraman_* , 06 Oct 2023 |
Designing The Internal Dimensions Of The Grease TrapStarted by Guest_rezagholipoor_* , 10 Dec 2022 |
Variable Speed Pumps Operation.Started by Guest_panoska_* , 11 Oct 2022 |
