Well Head Flowline.
#1 Narayanan.u
Narayanan.u
  • 30 posts
Posted 28 October 2010 - 11:26 PM
Hi everyone,
We are beginning to design a well head gathering system. A typical PFD (attached) of a well head has been given as a guideline. As you can see the choke valve is directly connected to the wing valve flange before the Shut Down valve. I have seen the choke valve installed a few feet down stream after Shut Down valve. The latter give flexibility to tie in of flow lines to well head.
Attached File  Attachment-4 Wellhead Piping and Control System.pdf   17.75KB   94 downloads
Please give your comments/ advise on both arrangements. Advantages/disadvantages of both from your experience.
U.Narayanan
#2 Narayanan.u
Narayanan.u
  • 30 posts
Posted 11 November 2010 - 04:23 AM
Being a low pressure well less than 1400 psi the above arrangement is fit for pupose as per recomendation.
Narayanan
