Through the combination of mechanical plant on-site observation of dynamics grinding mill, ball mill found in the actual production of coarse there is a reasonable position phenomenon, is now thrown down on the ball mill grinding body type and material movement trajectories and between force analysis, and explore the causes of this phenomenon. Found that the feed mill at the feed point selection device exists unreasonable. Thereby reducing the ball mill grinding efficiency and increased consumption. So in order to optimize the feeding device, to improve the irrational, the need for improvement of the feed point.
Improved mill feed inlet design
In recent years, as new technologies, new technology continues to improve, when the output of Taiwan ball great changes have taken place, with the specifications of the raw material open and closed-circuit grinding mill table and more than double the yield difference. Into the grinding particle size reduction, increased mill ventilation, to improve the mill's output, quality played a key role. To improve the mill ventilation, many factories have been made in this great effort and exploration. Set in the grinding mill to increase the blast and the combination of the end of ventilation, received a good effect, but correspondingly increases the energy consumption of the fan tail mill dust collection system with treatment difficult. Therefore the most effective way is to improve the feed inlet.
First, the device integration trend. As the number of modern dressing products and product objectives increasingly demanding taste. Therefore, when the selection of equipment manufacturers of crusher, prefer complete production line, due to the production line equipment for other equipment is optimized, can improve production efficiency and ease of manipulation.
Second, the process of localization trends. With the domestic research level, the recent patent application processing equipment significantly more emphasis on the support of their research results. Well, this will also encourage excessive scientists, mineral processing equipment for China to catch up with the world interested in the contribution to the advanced level.
Third, the device intelligence trends. As more research institutes, new thinking and new methods developed, and a variety of intelligent control theory applied successfully in other industries, with more advanced intelligent processing equipment manufacturers in the laboratory for debugging. I believe in the near future, a large number of new products will be filled with the intelligent processing equipment market.
Fourth, the production process of the trend. For a modern mineral processing nearly 40 years of experience, the major equipment manufacturers have begun to consider custom expert system for the entire production process customized for different geographical environments the most reasonable solution.
Five semi-automatic welding trend. This technique mainly for mineral processing equipment in contact with highly corrosive materials in the machine. This can reduce the oxygen by the application of welding, the use of new solder can improve the durability of the equipment 50% -75%.
At the control simple trend. In recent years, manufacturers of equipment to facilitate rapid application in the production line has been gradually integrated one-touch control, even if the manufacturers do not have professional machine control temporary staff can be achieved by simple control production. This is an expert on technology of enrichment.
VII, green energy trend. Since early this year after the Copenhagen conference, jaw crusher world leaders at the summit has made commitments. The industry is now the state will take measures to reveal excessive production of electricity industry to adopt more stringent environmental control. Then, using advanced technology applications of green energy-saving products selected will give a better chance of survival plants.
VIII, manufacturing orders trend. In the past, device model, performance, and more fixed, firms tend to have a certain stock. The specific customer needs at this stage because the increasing refinement of compounds, a direct result of manufacturing companies have to pursue the theory of the nominal zero inventory efforts.
September, equipment form the trend in Europe and America. In the experience of other countries, advanced manufacturing technology, shape of the device technology, the shape of the design of mineral processing equipment will gradually move closer to Europe. The new shape design can often make the customers more choice and want to try, long-term view, conducive to the overall development of the field of mineral processing equipment.
Ten, the device large-scale trend. Mainly for ball mill, the state has explicitly introduced the policy to terminate the 3.5m diameter of the end of the year following the production of small ball. This will inevitably lead to the manufacturers in order to seek development and survival, and have a higher technical difficulty of the new trial and a large mill.
Ten Year Trends In The Development Of Mineral Processing Equipment
Started by sunshine20520, Nov 21 2010 10:26 PM
No replies to this topic
Posted 21 November 2010 - 10:26 PM
How About An "in Development" Section In Downloads?Started by Guest_Chris Haslego_* , 24 May 2012 |
![]() Sand Handling And ProcessingStarted by Guest_Kakashi-01_* , 23 Jun 2023 |
Equipment Spec SheetsStarted by Guest_Ken Bicknell_* , 07 Jun 2023 |
Heat Losses Of EquipmentStarted by Guest_panoska_* , 20 Oct 2022 |
Gas Processing Unit At Low TurndownStarted by Guest_hira488_* , 14 Oct 2022 |
