Fired Heater Design
#1 binzee
binzee
  • 55 posts
Posted 01 December 2010 - 09:28 AM
We are in the process of purchasing a fired heater for our 6000 BPSD light sweet crude atmospheric distillation unit. The process of design and fabrication will be done by some well known engineeirng company.
I would like to know, for my understanding and for the sake of own engineering exercise, what are the sources of literature which should be used to design a fired heater apart from simulation programs (simulation programs came in to use very late and manual calculation was the rule)
If i were to design a fired heater on my own using long hand calculations, what should be the starting point and what literature should be utilized.
Any advice from Che Jedis' would be highly appreciated
Kind regards,
Edited by binzee, 01 December 2010 - 12:40 PM.
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 01 December 2010 - 11:49 AM
binzee,
D Q Kern - Process Heat Transfer has a dedicated section for fired heaters
W L Nelson - Petroleum Refinery Engineering has a chapter on Fired Heaters
ANSI/API STD 560- Fired Heaters for General Refinery Service 4th Edition
Some literature for fired heaters as mentioned above
Hope this helps.
#3 breizh
  • 6,714 posts
Posted 01 December 2010 - 08:24 PM
additional info could be found on this link:
http://www.heaterdes...com/design0.htm
Hope this helps
#4 binzee
binzee
  • 55 posts
Posted 05 December 2010 - 07:41 AM
Dear Ankur & Breizh
Thank you for your response, currently i am going through the references cited.
In the mean time other references would be much appreciated
regards,
Edited by binzee, 05 December 2010 - 07:42 AM.
#5 kkala
kkala
  • Banned
  • PipPipPipPipPip
  • 1,939 posts
Posted 17 December 2010 - 12:35 PM
Following thread from the forum can be also helpful as a specific example for the design:
http://www.cheresour...h__1#entry41198
