How To Find Activity Coefficients
Posted 27 January 2011 - 09:36 PM
I'm a recent ChE grad working on a consulting project and I need to develop a pressure vs. temperature curve for a system of dimethyl ether / ethanol. My thoughts are to model this using a modified Raoult's Law (although open for suggestions here).
Unfortunately I don't have access to the software I used as an undergrad (Aspen, etc.) to obtain the activity coefficients. Just wondering if anyone knows of an inexpensive / free-ware alternative that will calc. these parameters using UNIFAC, etc.
Thanks,
- Brian
Posted 28 January 2011 - 12:36 PM
Thanks,
- Brian
Modified Raoult's law seems fine, as long as you are staying at low pressures where you can safely assume the vapor is an ideal gas.
There are several UNIFAC calculators out there. Put "UNIFAC calculator" into your favorite search engine and you should find several.
If you are allowed to, it wouldn't be that difficult to write your own code/spreadsheet for UNIFAC (or other activity coefficient equation such as the Wilson, NRTL, or UNIQUAC). I would actually recommend this course of action because, not only will you get an activity coefficient calculator, but you'll become more familiar with the equation(s), and you will have a code block/spreadsheet that you can adapt to whatever situation you find yourself needing.
Because it is an estimation method, I don't usually like to rely solely on UNIFAC. I would generally prefer to use real VLE data to correlate NRTL or Wilson parameters. Again, this shouldn't be too difficult to program on your own (especially when you can assume ideal gas in the vapor).
Hope that helps.
Posted 29 January 2011 - 05:28 AM
I have attached file for calculating VLE for ethanol & water mixture using UNIFAC group contribution method. This i created for my own study purpose.
I recommend you to go through the book properties of gases & liquid by Bruce poling.
Hope the template & model may be useful to solve / create activity coefficient data for any compounds you want.
Cheers
MK_CHEM
Posted 07 February 2011 - 07:08 AM
Do not rely only on UNIFAC. It is easy to code UNIQUAC or NRTL and find , or regress, the proper coefficients.
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
![]() Find The Lowest Delivering Cost By Minimizing The Objective FunctionStarted by Guest_chemtoli_* , 30 May 2023 |
Are Defined Norms For Coefficients Of Discharge?Started by Guest_SPCon_* , 22 Aug 2022 |
How Can I Find The Hept Of Glass Raschig RingsStarted by Guest_peruanolimense_* , 04 Feb 2022 |
![]() How To Find The Relief Load For The Fire CaseStarted by Guest_Sami222_* , 18 Jan 2022 |
