There are options to traditional methods of water treatment. You can contact me directly, as this is not a forum for advertising products.
In short though, the use of advanced technologies to develop and maintain dispersions allows you to carry a high TDS bulk solution. This high TDS solution, will naturally buffer out to a pH of 8.9 or so, providing the anti-corrosion qualities you seek. The persistent dispersion protects the system from scaling, along with inhibiting biological growth.
These systems are used throughout the world, and may be worth looking into if you are serious about improving the water quality and performance of your cooling tower water systems.
Prior to one year back, we were using Borewell water as Cooling water in our Ammonia-Urea complex. Now we have switched over to canal water for all the water requirement in the complex. Water requirement includes Process Water, Cooling Tower make-up water. The analysis of both types of water is attached for reference.
Earlier, we were using molybdate treatment for corrosion prevention in Cooling Tower.
My query is that whether can we stop using molybdate treatment in Cooling Tower for corrosion prevention at present with such Canal water analysis and switch over to some cheaper mode of corrosion inhibition.
To add more information, We have 14 nos. induced draft cross flow type cooling tower cells (total cooling water circulation capacity of 27130 m3/h.
