Reciprocating Pump
#1 Mahesh@A&M
Mahesh@A&M
  • 80 posts
Posted 12 February 2011 - 09:08 PM
Could you please suggest couple of reciprocating pump manufacturers for pumping 3% calcium chloride solution.
Design Conditions:
Liquid: 3% Calcium chloride solution
Temperature: Ambient
Flow Rate: 0.5 to 1.0 GPH
Pump discharge pressure: 90 psig
Suction pressure: 2 psig
Calcium chloride being corrosive, I am procuring PE lined piping and valves with PTFE liner.
Thank You
Mahesh
Edited by Mahesh@A&M, 12 February 2011 - 09:10 PM.
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 13 February 2011 - 01:21 AM
Mahesh,
Some of the best low capacity diaphragm or plunger pumps are manufactured by the following companies. I have used their products and found them quite reliable. The MOC can be tailored to suit the corrosion properties of the pumped fluid.
LEWA pumps+Systems
Milton Roy
Below are the links to their websites:
http://www.lewa.com/main/en/1874/
http://www.miltonroy...ETI3654,00.html
#3 breizh
  • 6,715 posts
Posted 13 February 2011 - 02:01 AM
Mahesh,
My preference will be for Milton Roy , I will add Blackmer and Delasco to the list.
Hope this helps
#4 Mahesh@A&M
Mahesh@A&M
  • 80 posts
Posted 13 February 2011 - 11:37 AM
Thank You very much!!!
#5 Art Montemayor
Posted 13 February 2011 - 12:11 PM
Mahesh:
I would recommend you contact Milton Roy here in Houston and work with them on this application. I would seriously try to stay away from a plunger-type pump and would try to apply a hydraulic diaphragm-type of pump. Milton Roy has various types and configurations as I recall and can be of great help.
Don't under estimate this type of application. Try to specify and build on Milton Roy's expertise in the field. They have had to pump every imaginable type, color, viscosity, slurry, corrosive that you can imagine. Ask them for recommendations - but based on your SPECIFIC needs and detailed description of fluids and conditions.
Hope this helps.
#6 Mahesh@A&M
Mahesh@A&M
  • 80 posts
Posted 13 February 2011 - 12:54 PM
Thank You Mr.Art.
I will get my data sheet ready and contact them this week.
Thank You
Mahesh A&M
