Sparger Design
7 replies to this topic
#1 Guest_ANSHUL AGRAWAL_*
  • guestGuests
Posted 04 June 2005 - 12:46 AM
Hi Group,
I am working on a sparger design for gas liquid operations and seeking your help.
Based on Mott Corp. design procedure, i Have designed the sparger but the problem is i am getting no of holes too high. ( 4066, for hole dia of 2 mm).
Design procedure available at http://www.mottcorp....arger_guide.pdf
Kindly suggest me whethere this is correct or not.
Please send me some literature/links on sparger design for gas liquid operations.
Hope to hear some helping words soon.
Thanks & Regards
Anshul
Posted 04 June 2005 - 10:04 AM
Anshul:
I think your difficulty lies in the way you are interpreting the Mott data and spargers. You will note that they employ a porous medium for the creation of micro-sized, multiple gas bubbles. The area that they calculate relates to the super-efficient area of their “elements” – their porous media.
You, on the other hand are converting this area to conventional, circular holes. This is OK, but you can easily visualize how a conventional circular hole is not competitive with a porous medium in lending effective, sparging area to a gas.
When I have required multiple, efficient sparging area I have always resorted to using something similar to what Mott employs: sintered bronze or sintered stainless steel. Many machine shops or foundries located in developing countries can produce this type of element if they are requested to do so. You will find that a properly manufactured sintered stainless steel element will produce such fine and dispersed bubbles that the required area you calculate will be far less than the element you employ.
The one, important problem in using sintered elements for spargers is that the fluids – particularly the parent liquid fluid – must be essentially pure and clean, and not be very viscous. The closer to water viscosity it is, the better the sparging operation. Slurry or dirty liquids will plug or negatively affect a porous sparger. If you are located in a developing country, I would try to have a sintered stainless element made locally and I would employ as much area as I could after experimenting with the element and its sparging action.
#3 djack77494
djack77494
  • 1,282 posts
Posted 04 June 2005 - 01:24 PM
Anshul:
For very simple (holes in a pipe) type of spargers where you'd like to get somewhat equitable distribution of the introduced fluid, I have designed spargers using a very simple criterion. As long as the pressure drop through the sparger holes significantly exceeds the fluid's velocity head, the fluid should tend to equitably distribute itself through the holes. I like to use a dP of at least 4 velocity heads, but this is totally arbitrary. Consider the liklihood of solid contaminants, including some pipe scale, being present in deciding on what hole size to specify. Again, it's totally arbitrary, but I like to specify a hole size of at least 1/8 inch (6 mm) diameter. With your preliminary design, as above, decide on whether you are satisfied with the number and layout of holes, and iterate as needed. For large systems, you very likely would employ a manifold system to provide good distribution of the introduced fluid.
Good Luck,
Doug
#4 anshulagr
anshulagr
  • 9 posts
Posted 09 June 2005 - 07:48 AM
Thank you group for your valuable inputs.
Anshul
#5 Guest_Annee_*
Guest_Annee_*
  • guestGuests
Posted 10 June 2005 - 07:25 AM
Dear anshul
in which company u r working here ?
Annee
#6 sdarone
sdarone
  • 18 posts
Posted 22 June 2005 - 12:22 PM
Anshul,
There was an article on the chemical engineering, april6, 1981, titled: hole-area distribution in liquid spargers, this article shows a program (iterative) to dimension the area of the holes in the TI-59 calculator, this one is a correctio to a previous article, about the same issue, but were velocity head was not considered in the equation.
I encourage you to read this article... you will find that the first orifices in the sparger must be larger, that the ones at the end, in order to have a good distribution.
Hope this Helps.
Sergio
#7 SPEORC
SPEORC
Posted 13 September 2005 - 12:36 PM
Sergio,
I am looking for details of sparger design for liquid distribution in vessel filled with water. I think an article on the chemical engineering, april6, 1981, titled: hole-area distribution in liquid spargers will be useful for me. I am unable to get this article. Can anyone post this article to my e mail id joshivinayak@gmail.com.
Thanks,
Vinayak
#8 SPEORC
SPEORC
Posted 13 September 2005 - 12:37 PM
Sergio,
Thanks,
Vinayak
