Help With Three-Effect Evaporator
Started by peaston, Feb 24 2011 01:12 PM
Posted 24 February 2011 - 01:12 PM
2. A forced-circulation triple-effect evaporator using forward feed is to be used to concentrate a 10 wt % NaOH solution entering at 37.8°C to 50%. The steam used enters at 58.6 kPa gauge. The absolute pressure in the vapor space of the third effect is 6.76 kPa. The feed rate is 13608 kg/h. The heat-transfer coefficients are U1 = 6246, U2 = 3407, and U3 = 2271 W/m2 · K. All effects have the same area. Calculate the surface area and steam consumption.
Was given this question, which takes for ever to do... I am having trouble finding out the boiling point rises, BPR1, BPR2, BPR3, over each stage... We were given an example in class which was similar but the solution being used as a sugar solution, in which it was easy enough to get a bpr using an equation: BPR = 1.78x_1 + 6.22x_1^2, but i think for the case with this NaOH solution, we have to use Duhring charts...
Can anyone please give me some feedback on what they would do in this question
many thanks in advanced
andrew
Posted 24 February 2011 - 03:25 PM
Andrew:
You haven't submitted your work product on this problem. Does this mean you want us to produce it for you? Why don't you produce your work on a spreadsheet format so that you can show where you are stuck and we can see how you are proceeding to obtain the answer? That would be a fast, efficient, and effective way to transmit comments and suggestions to you on what you are doing well and what you are doing wrong.
Posted 24 February 2011 - 06:31 PM
Andrew ,
Process heat transfer by D.KERN should support your query .
Regarding boiling point , I've attached a link .
http://www.solvaycau...005_w_en_ww.pdf
Hope this helps
Hope this helps
Posted 25 February 2011 - 07:48 AM
drew:
As am not currently at home i do not have my D Q Kern with me.I remember solving such questions in my college days.Your problem is with finding the boiling point elevation.Using the Duhring's plot is not difficult but there are somethings which you must know:
1.The system pressure in each effect,i hope you have probably calculated that.
2.The solute concentration of the solution from each of the effect.I hope you have done that too.
For your system pressure i.e. the pressure in the effect concerned obtain the boiling point of pure water,this could be obtained from steam tables.
Next enter the DUHRING'S plot from the bottom(the boiling point of pure water which you obtained from steam table) then trace up to the concentration percent concerned.
Now go left and read the solution boiling point on the vertical axis,the difference between the two temperatures is the boiling point elevation.
Effect Of Continuous Blow Down To Boiler Feed WaterStarted by Guest_Dyames027_* , 21 Nov 2024 |
![]() Heat Transfer In Jacketed EvaporatorStarted by Guest_haseeb00718_* , 19 Aug 2024 |
![]() Multiple Effect Evaporation 5 Stage CalculationStarted by Guest_pentakota.koti_* , 26 Jun 2018 |
![]() Effect Of Bundle Entrance Rho-V2 And Tube Material Of Shell And Tube TStarted by Guest_prince1pahariaa_* , 21 May 2024 |
![]() Multiple Effect Evaporator Calculation With Multiple ComponentsStarted by Guest_addiesalsabil_* , 13 Jan 2024 |
