Changing The Ph By Adding Acid.
Started by Chemed, Feb 28 2011 04:32 AM
Posted 28 February 2011 - 04:32 AM
I have a 55 000L body of water, and 9 mol/L concentration of hydrochloric acid. How much acid do I need to add to change the pH from 8.1 to 7.2? Please show calculations.
Posted 28 February 2011 - 06:28 AM
Chemed ,
knowing that ph =-log10(H+) should be a good start to solve your query .
Acidity of the liquid :
Initial : H+ = 10^-8.1 mole/l before acidification
Final : H+ = 10^-7.2 mole/l after acidification
Mass balance
Initial : 55 000 liters
Final : 55 000 liters +Y l acid
H+ Balance
(550000 + y) * 10^-7.2 - 55000 * 10^-8.1 = y *9 >>>>>then you can calculate y
Hope this helps
Mass balance
H+ Balance
Hope this helps
Posted 05 March 2011 - 10:55 PM
Hi Chemed,
Breizh is completely right for pure water, however impure water may contain buffers which will change the response of the water to addition of acids and bases. Is this a theoretical question or are you actually attempting to change the pH of the body of water?
In order to test the response of the water to acid addition, it is necessary to construct a pH curve.
You can also perform the titration in one go (simply adding enough acid to reach pH 7.2) however this won't allow you to understand the response of the water to the acid.
Adam
- Start off by collecting a water sample (eg. 100 mL) and transferring this to a beaker (eg. 250 mL).
- Immerse a pH probe in the water to determine the initial pH.
- From a burette (10 - 50 mL capacity), add just enough acid to change the pH by 0.1. Repeat until you reach pH 7 or below.
- Plot the a curve of the amount of acid added and the resulting pH
- Calculate the amount of acid required to change the pH to 7.2. Multiply this value by 10 to find the amount of acid required per litre of water; from this you can then multiply by the volume of the body of water (55,000 L in this case) to find the total acid required.
Adam
Chemed ,
Mass balance
H+ Balance
Hope this helps
![]() Equilibrium Data For Nitric Acid And WaterStarted by Guest_ksagarzazu_* , 07 Oct 2024 |
Adding Inlet To Compressor Through Vba (Hysys/unisim)Started by Guest_Matylda_* , 30 Jul 2024 |
Adding Components Through Vba To HysysStarted by Guest_Matylda_* , 26 Jul 2024 |
![]() Acid Base ExtractionsStarted by Guest_paradoxlost_* , 07 Jul 2024 |
