Difference Between An Elbow And A Bend
10 replies to this topic
#1 SAprocessGD
SAprocessGD
  • 22 posts
Posted 07 April 2011 - 11:45 AM
Hey,
With regards to pipe fittings,
It is my understanding that an elbow consists of a sharp "bend" usually at 45 or 90 deg angles. What is the difference between an elbow and a bend - or are they considered the same type of fitting?
Feel free to add any additional information. Thank-you!
Posted 07 April 2011 - 12:33 PM
An "elbow" and a "bend" are two different animals - as the terms are generally employed in the process industry.
A BEND is the generic term for what is called in piping as an "offset" - a change in direction of the piping. A bend is usually meant to mean nothing more than that there is a "bend" - a change in direction of the piping (usually for some specific reason) - but it lacks specific, engineering definition as to direction and degree. Bends are usually custom-made (using a bending machine) on site and suited for a specific need.
An ELBOW, on the other hand, is a specific, standard, engineered bend pre-fabricated as a spool piece and designed to either be screwed, flanged, or welded to the piping it is associated with. An elbow can be 45o or 90o. There can also be custom-designed elbows, although most are catagorized as either "short radius" or long radius".
A bend can be an elbow; an elbow does not mean a bend. If you use the term elbow, it should also carry the qualifiers of type (45 or 90o) and radius (short or long) - besides the nominal size.
  • guestGuests
  • 0 posts
Posted 08 April 2011 - 12:39 AM
Additionally, if you are using tube and not pipe, there is a marked difference. As you can bend tube for pressure applications you will get less interuption and turbulence in your flow; this translates to less pressure drop than with fitted 90 or 45 elbows.
#4 Vimalesh Agnihotri
Vimalesh Agnihotri
  • 15 posts
Posted 09 April 2011 - 10:59 PM
Art Montemayor:
Good Explanation. Thanks.
#5 rowanlim
rowanlim
  • 51 posts
Posted 15 April 2011 - 01:16 AM
Thanks for the explanation, now I learned something new! :)
#6 ogpprocessing
ogpprocessing
  • 142 posts
Posted 22 April 2011 - 03:43 PM
Dear Art,
Could you please explain us about the difference between short radius and long radius elbows? And for which specific applications long and short radius elbows should be used?
#7 Modesty Blaise
Modesty Blaise
  • 11 posts
Posted 22 April 2011 - 06:20 PM
Long radius elbow is used to change the direction of flow gradually, 90 degrees.
Short radius elbow is used to change the direction of flow rapidly, 90 degrees.
45° elbow is used to change the flow only 45°.
Return bends are used to change the direction of flow 180°.
Edited by Modesty Blaise, 22 April 2011 - 06:36 PM.
#8 Art Montemayor
Posted 22 April 2011 - 08:17 PM
ogpprocessing:
The physical difference between Long Radius and Short Radius Elbows is graphically illustrated in the attached Workbook that I have put together for this thread.
The following is the criteria I use when deciding which to use:
Long Radius Elbows are used when:
  • there is a need to keep the frictional fluid pressure loss down to a minimum;
  • there is ample space and volume to allow for a wider turn and generate less pressure drop;
  • the fluid being transported is abrasive or has solids in it.
Short Radius Elbows are used when:
  • there is a need to reduce the cost of elbows;
  • there is a scarcity of space and volume to allow a Long Radius type.
I hope this helps.
#9 nmh
nmh
  • 10 posts
Posted 27 April 2011 - 08:56 AM
Thanks for info
#10 Madhan Kumar
Madhan Kumar
  • 14 posts
Posted 28 April 2011 - 02:44 AM
Dear Art Montemayor Sir,
Thanks for your useful spreadsheet.
Cheer's
MK_Chem
#11 Elizabeth_I
Elizabeth_I
  • 8 posts
Posted 28 April 2011 - 04:53 AM
Thanks for the information, it's amazing to find the answers here!
