As we know, gases are compressible in nature and thefore their density varies with temperature and pressure.
I want to select Cv value for nitrogen blanket line flow control valve. Basically this line has inlet pressure of about 2barg and nitrogen passes through a flowmeter, 1off non return valve, 2off isolation ball valves, flow control valve [FCV] and then to the reactor. Looking to the pressure drop across all these upstream equipments on FCV, I came up with FCV inlet pressure of about 1.5 barg, 1.7barg and to 1.8 barg for let's say three different flow conditions i.e. maximum , normal and minimum flowrates which are respectively 15m3/hr, 5m3/hr and 1m3/hr. I got these 3off flowrate conditions from client. The reactor is operated at an atmospheric pressure and the length of pipe from FCV is about 5m and therefore pressure drop across pipe is negligible and therefore I have arrived downstream pressure as about 1.49 barg, 1.69 barg and 1.79 barg approximately for above 3off flow conditions.
I have estimated Cv at NTP [i.e. 15 deg C and 1.01325 bar pressure] i.e. nitrogen density of about 1.18 kg/m3. However, I think there are THREE different possibilities to calculate Cv values i.e. at NTP, STP and Actual conditions. COULD SOMEBODY CLARIFY IF MY UNDERSTANDING IS CORRECT?
I have estimated Cv at NTP as I dont know if the above flowrates [which client gave me] are at NTP i.e. Nm3/hr.
However, I think if above flowrates are measured at an actual temperature pressure conditions [i.e. at temperature of about 15 deg C and pressure of 1.5barg, 1.7barg and 1.8barg], Cv values should be calculated based on actual conditions. If I calculate Cv based on actual conditions, I have to take density of nitrogen in the range of 3kg/m3 which give different Cv value than Cv at NTP conditions. Am I correct?
Meanwhile, I confirm from client, what conditions they have measured the above flowrates, any guideline on above will be appreciated.
Thanks,
KS
Edited by KS2010, 18 April 2011 - 04:58 PM.
