Heats Of Reaction H2so4/naoh With Water
#1 Nick (6 Engineering Ltd)
  • 24 posts
Posted 28 June 2005 - 09:46 AM
I need to find out heats of reaction (in order to calculate temperatures) for the following reactions:
H2SO4 with water
NaOH with water
Does anybody either have this info or know where I can find it?
Thanks in advance,
Nick
#2 mbeychok
mbeychok
  • 364 posts
Posted 28 June 2005 - 12:12 PM
Jellybean:
I think what you want is the heat of dilution. The web site given below has a graph of the heat of dilution for H2SO4 (in Btu per pound of H2SO4 versus the weight percent of H2SO4 in the resulting solution):
www.resistoflex.com/sulfuric_graphs.htm#5
I would suggest you do a Google search to find similar data for the heat of dilution of sodium hydroxide.
#3 siretb
siretb
    ChE Jedi
  • 304 posts
Posted 29 June 2005 - 03:52 AM
I have a graph, that comes from "selected values of Chemical Thermodynamics Properties", US department of commerce, 1952, page 449
I do not use it (I have a software package), but if it may help here are a few points starting with 25°C water
heat released (calories per gram of NaOH), versus final concentration ( in g/100g of solution), during dilution.
I hope this helps.
0 (g/100g) 255 (cal/gram NaOH) / 15 255 / 20 250 / 30 230 / 35 208 / 40 196
#4 gvdlans
gvdlans
  • 619 posts
Posted 29 June 2005 - 01:18 PM
Handbook of Chemistry and Physics, 67th edition, page D-122.
Heat of Solution for NaOH at 25°C in water: -10,637 cal/mole
#5 Nick (6 Engineering Ltd)
  • 24 posts
Posted 30 June 2005 - 02:30 AM
Thank You all very much for your replies
Much appreciated
Nick
