Equation Of State For Steam
#1 Phukan
Phukan
  • 19 posts
Posted 22 June 2011 - 09:52 AM
I want to know the temperature of steam downstream of a control valve which is a at a pressure of 19.77 kg (I assume it to be saturated) upstream of the control valve. The pressure shown downstream of the control valve is 6 kg per sq cm. what equation of state should I use. Is it reasonable to assume it to be saturated and refer to steam table which gives it a value of around 158 deg cel. However, using the ideal equation of state gives it a value of 147 deg cel(assuming V to be constant).
#2 abhi_agrawa
abhi_agrawa
  • 216 posts
Posted 22 June 2011 - 10:58 AM
Phukan,
Use steam tables for accurate results. Also the steam upstream of the control valve would in all probability be superheated and not saturated.
abhishek
#3 kkala
kkala
  • Banned
  • PipPipPipPipPip
  • 1,939 posts
Posted 22 June 2011 - 02:49 PM
Adding a bit to previous post, one can consider isenthalpic expansion of steam from 19.77 kg/cm2 a to 6 kg/cm2 a. In the specific case steam temperature falls from 211 oC upstream to about 176 oC downstream of valve, versus a saturation temperature of about 158 oc.
One can use a simulator for the above results, instead of steam tables.
#4 katmar
katmar
  • 687 posts
Posted 23 June 2011 - 05:54 AM
Assuming that the valve is well insulated, and because no work is being done, you can regard it as an isenthalpic process for all practical purposes. I would use steam tables to see that the enthalpy of saturated steam at 19.77 kgf/cm2 absolute is 2795.1 kJ/kg. In order for steam at 6 kgf/cm2 absolute to have this same enthalpy it would have to be at 175.3 °C, i.e. slightly superheated.
If the initial steam quality was not 100% then this outlet temperature would be a bit lower.
The temperature can certainly not be below 158 °C because that would imply that it is all liquid, and we know that does not happen in a valve.
#5 EyMiller245
EyMiller245
  • 7 posts
Posted 23 June 2011 - 10:39 AM
Steam and water vapor should never be treated as ideal gas if at all possible. Always use tables or more rigorous equations of state.
Edited by EyMiller245, 23 June 2011 - 10:42 AM.
