i would like to ask does anyone can help me to calculate the quantity of water/air needed for cooling the condense from incineration plant! Namely, I am working on my master thesis and in the area where i proposed to be the location for building the plant there is not enough water for cooling. That's why i recommend hybrid cooling towers but unfortunately i don't know how to calculate the amount of water/air needed for cooling of the condense.
Thanks in advance for any help and assistance!
Hybrid Cooling Towers
Started by Marija, Jul 02 2011 12:48 PM
Posted 02 July 2011 - 12:48 PM
Posted 02 July 2011 - 08:08 PM
It's all about mass and energy balances ! For heat tranfer , let you try to find "Kern -Process Heat transfer"
I've attached documents which may help you to understand Cooling Tower.
Additional resource could be phone call to suppliers of this technology.
Hope this helps
Hope this helps
Posted 04 July 2011 - 01:04 PM
What kind of "hybrid cooling" are you referring to? This term is normally used for air-cooled heat exchangers, in those instances when cooling is enhanced by spraying demineralized water across the cooling air path before fin-fan tubes are reached.
Please post a sketch of what are you proposing, and probably we will be able to provide some more help.
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
![]() How Can I Simulate An Adsorption And Deoxidization Towers In Aspen HysStarted by Guest_Ahmed.Loutfi_* , 03 Nov 2024 |
![]() Pressure Loss In Piping - Cooling Tower-Shelltube HeatexchangerStarted by Guest_Alneto_* , 29 May 2024 |
Chiller Efficiency Dependence On Cooling Water TemperatureStarted by Guest_Neha Vensiyani_* , 29 Apr 2024 |
Sizing Of Cooling Water Pipe LineStarted by Guest_Asif Azeez_* , 08 Jan 2021 |
