Recycle Split-Vapor (Rsv) Process
#1 Hamidihizami
Hamidihizami
  • 9 posts
Posted 18 July 2011 - 08:22 PM
Hi
Now I am developing Recycle Split-Vapor (RSV) process for NGL recovery process based on Ortloff but I encounter a problem. When I run this simulation, a consistency error has occurred. The composition at gas outlet for demethanizer in column environment and simulation environment is different. I don't know what to do. Below I attached my simulation. All your help is highly appreciated. Thank you
  • Attached File  RSV.zip   87.39KB   50 downloads
Edited by Hamidihizami, 18 July 2011 - 08:25 PM.
#2 shan
shan
  • 692 posts
Posted 19 July 2011 - 07:44 AM
Hi
Hi Hamidihizami,
I am unable to open your attached zip file. Usually, inconsistency is because your over specified one or more process parameters in your simulation.
Shan
#3 Hamidihizami
Hamidihizami
  • 9 posts
Posted 19 July 2011 - 11:16 AM
Dear Shan,
Thanks Shan for the info but I still don't get it. If I eliminate one of the parameter, the column will not solve. So, which parameter I should delete? Anyway, if you had problem to open the simulation, I can email you. All your help is highly appreciated
Edited by Hamidihizami, 19 July 2011 - 11:16 AM.
