Posted 08 August 2011 - 10:27 AM
“Combustion gas oil” is assumed to be burnt in gas turbines (GTs) to produce electricity and steam (cogeneration). Mentioned GT “constraints” for viscosity, moisture, sulphur, could be kept when jet fuel is replaced with light naphtha (this can be verified in the lab, yet no problem is generally anticipated). Having no operating experience and limited theoretical knowledge, I can only share thoughts as below:
1. GTs met in earlier studies were able to burn following fuels , without change in efficiency.
-Natural gas, as well as diesel as backup (32 MW)
- Diesel or commercial propane (not butane or LPG, 18 MW).
-Natural gas, as well as diesel as backup (380 MW). Supplier had placed diesel specifications (concerning its chemical compounds) stricter than commercial diesel (due to risk of plugged injection into burning chambers), but these were alleviated by pointing out that diesel was for backup (1-2 days/year).
2. Consequently a single gas turbine can be flexible enough to burn a variety of fuels from natural gas to diesel. GTs are not like internal combustion engines, where a change in fuel composition causes change in its cetane (or octane, or methane) number, thus risk of knocking. In this sense, substituting jet fuel with naphtha in their feeding fuel does not anticipate a problem, at least at first look.
Jet fuel specifications require not to solidify in -50 or -60 oC ; this is not of concern for GTs operating at grade at ambient temperatures.
However possibility for any precipitate, resulting from mixing gas oil with naphtha, should be excluded (as pointed out by Technical Bard) by laboratory tests. Contrary to gasoline blender, naphtha added to diesel blender is of unknown consequences to me, concerning potential precipitates (that would plug the GT injection).
3. Some reserve is indicated, since some points of gas turbine operation have not been understood (e.g. why mentioned 18 MW turbine could not burn butane?). I would first check fuel specification in GT manual; then ask advice from GT supplier”. Efficiency may be retained, but some other factor could create need of more frequent maintenance, thus reducing operational availability. It is probable that even supplier does not know potential problems in detail, you will know them (if any) by long term operation. A trial may be worth while, unless warned about a specific problem related to naphtha.
