What Is Depressurisation?
Posted 14 August 2011 - 08:08 AM
What is depressurisation? WHy is it done? Where I can read about the basics about this issue?
Is there any calculation sheets available and can somebody help me with some examples? I am very new and hence please elaborate with patience.
Posted 16 August 2011 - 09:08 AM
I have met depressuring as an emergency operation on two towers in a hydrodesufphurization unit. Little area of them was wetted in case of fire. So their vapor load should be discharged to flare through two remotely operated valves, one for each tower. This was manually in that case, before PSVs opening; there are more sophisticated cases where valves are automatically operated through a programmable software.What is depressurisation? WHy is it done? Where I can read about the basics about this issue?
http://boonchoo.org/... Philosophy.pdf is an introduction to depressuring and its intents. Placing "depressuring" or "depressurizing" in the forum search engine will reveal a lot of information to select the interesting part, e.g. http://www.cheresour...h__1#entry43685
Edited by kkala, 16 August 2011 - 09:09 AM.
Posted 19 August 2011 - 12:17 AM
Depressurisation is required for the following reasons:
1)To bring a system to a safe condition.Say a compressure is running at a high pressure(for process requirement)and suddenly the process tripped.There may be progamm to depressurise it to lower pressure level and the comressure will continue to run on recycle or it may be depressrise to a further lower pressure level and go for shut-down.
Or say a vessel pressure suddenly increased due to process abnormality.Then you have to deprssurise it(there may be auto venting system).
In case of fire, vessel pressure will increase and process vessels are fitted with thermal safety valves.
2)To make a vessel or equipment free of unwanted gas or vapour .Say we like to make a vessel free of some gas and fill it with N2.We first reduce the vessel pressure and then pressurise it with N2.We do it several times until the goal is achieved.Pressurisation/depressurisation is better than continuous purging.
3)For preservation purpose.We depessurise high pressure equipments to a just positive pressure to preserve it during shut-down condition.
4)For some tests.Say during hydro-test of a boiler,we have to pessurise it and later depressurise it in a planned way.
(There may be many other reasons where depressurisation is necessary)
Posted 19 August 2011 - 04:36 AM
Hi awesome,Hello,
and addition to above two examples, the moleseive dryer or adsorbers operation are best example,these are working on automatic sequence, in that out of two moleseive one will be in line and other will be in regenration mode, to change online molseive to regeneration mode first molsieve will go on depressurisation step in that inlet and uotlet XV'S of molesieve will close and depressurising XV will open to reduce pressure of molesieve safely to low pressure system and further it will proceed for regenration step i.e purging, heating,cooling and back to in line.
hope this will help thanks and regards
azzu
Posted 21 August 2011 - 07:34 AM
It helped. Isnt it Engineering fascinating, you keep discovering so much every day..
Back to depressurisation. I am been reading fair bit about this, however it will further help if
someone can share with me an example with calculation behind as well I read one needs some dynamic tools
to measure the temperature drop. It will help.
Hi awesome,
azzu
Posted 21 August 2011 - 10:36 PM
Let me give you a more specific example - compressed air system.
In most compressed air system, we have a pressure vessel called air receiver.Let say the operating pressure is 10 barG. Let say that the air receiver is due for inspection and maintenance. The pressure of the receiver must be emptied by 'depressurization' where the pressure is reduced from 10 barG to 0 barG (atmospheric) so that the vessel can be opened up inspection and maintenance. The depressurization process, in this case is simply venting the air inside the vessel into the atmosphere.
The calculation involved is normally to determine the time taken to empty the vessel or to depressurize from 10 barG to 0 barG.
1. Calculate sonic mass flowrate - refer to any fluid mechanic textbook for the sonic flow equation.
2. Calculate the mass of air inside the vessel using the Universal Gas Law (PV=nRT)
3. Calculate the time by dividing the total mass (step 2) with the mass flowrate (step 1) to arrive at the depressurization duration.
For temperature drop, you need to do enthalpy balance or use the adiabatic expansion process PV^k = constant and PV = nRT to express the temperature in terms of pressure ratio.
To gain more valuable experience, you need to do the calculation by yourself.
I hope the above example helps.
Edited by S.AHMAD, 21 August 2011 - 10:45 PM.
![]() Manual Depressurisation - How To Determine Restriction Orifice SizeStarted by Guest_FUNMILAYO_* , 14 Oct 2020 |
![]() Tank Depressurisation Through Vent Pipe CalculationStarted by Guest_lambonumber5_* , 08 Apr 2021 |
![]() Emergency Depressurisation Valve In Hydrocracker UnitStarted by Guest_Divid Kelin_* , 24 Apr 2021 |
![]() Choked Tank Depressurisation CalculationStarted by Guest_lambonumber5_* , 08 Apr 2021 |
Vessel Depressurisation Flow RateStarted by Guest_Ranga v_* , 09 Nov 2019 |
