PV=nRT
i want to fill up a line (of unknown length, as i have only P&ID) with N2 at know pressure and constant temperature. How can i calculate the volume of N2 needed?
any ideas.
thanks
Edited by engg, 15 September 2011 - 06:43 AM.
Posted 15 September 2011 - 04:50 AM
Posted 15 September 2011 - 06:59 AM
P&ID is not drawn under scale, neither does it show pipe elevations or downs; it is just a shematic diagram showing all lines. You can do the "line list" based on it (you have to know elevation differences too), but you cannot estimate the length of each pipe. Isometric or piping arrangement drawings are needed for "piping material take off" (revised at least three times during project implementation). Mentioned isometric / piping arrangement drawings are elaborated by piping designers / draftsmen, after having looked into P&ID, layout and existing piping drawings. They usually visit the field for clarifications.hi all; I wanted to know if it is possible to calculate volume of piping from P&ID alone? any ideas. thanks
Edited by kkala, 15 September 2011 - 10:14 AM.
Posted 15 September 2011 - 10:38 AM
Suppose that the physical length of your line is x. If d=internal diameter, total pipe volume is V=x*π*d^2/4, so ideal gas law can get the form n=(P*π*d^2 / (4*R*T))*x. This means that gas quantity n to fill this pipe line is proportional to line length x. So you cannot specify n without having specified x. Of course you can estimate an approximate length of pipe x and find an approximate quantity of gas n, assuming a pipe routing on a layout plan. Probably this is what you can do now that only PID has been prepared. Or you can measure / estimate pipe length on the field.hi all; PV=nRT
i want to fill up a line (of unknown length, as i have only P&ID) with N2 at know pressure and constant temperature. How can i calculate the volume of N2 needed? any ideas.thanks.
Edited by kkala, 15 September 2011 - 10:45 AM.
Posted 16 September 2011 - 01:32 PM
hi all;
PV=nRT
any ideas.
thanks
Posted 18 September 2011 - 12:13 AM
hi all;
PV=nRT
any ideas.
thanks
kkala's second response is right. The actual volume of gas you need is the actual volume of the pipe to be filled. You need to know the length.
hi all; PV=nRT
If pipe line has several diameters along its length, you have to estimate line length for every diameter and add the corresponding contents n.
Note: Do not consider previous post of mine, it is irrelevant. If I had looked at the label carefully, I might have then suspected the real question.
hi all;
PV=nRT
any ideas.
thanks
Edited by engg, 18 September 2011 - 12:15 AM.
Posted 18 September 2011 - 10:44 AM
Posted 19 September 2011 - 12:28 AM
thanks G8,Pipe A will need more nitrogen than pipe B on a mass basis but if the volume of pipe to be tested is the same then the actual volume of nitrogen required will be the same. The density of gas in pipe A will be greater.
Say for example that the absolute pressure required for pressure testing pipe A is two times than what is required for pipe B and that pipe A and B are the same volume. Assuming that the pressure testing is under conditions of pressure and temperature where the ideal gas law is applicable, then the density of nitrogen in pipe A will be twice that in pipe B. PV=nRT or density= MP/RT
Here's a better question: why are you pressure testing with nitrogen (a compressible fluid) instead of water (an incompressible fluid). It is safer to pressure test with water because if the pipe fails then there is no (or little) energy of decompression released. There are many historical references on this subject.
Is this for a pipeline?
Posted 21 September 2011 - 05:25 AM
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
![]() Constant Volume Vs Constant Mass Flow Of Centrifugal CompressorsStarted by Guest_panoska_* , 18 Nov 2024 |
![]() Pipe Entrance And Exit LossesStarted by Guest_katmar_* , 13 Nov 2024 |
![]() Nitrogen Leak Test On PipeStarted by Guest_mesbah_* , 24 Oct 2024 |
