Posted 21 September 2011 - 04:13 PM
I cannot see the things you claim that I should be able to see in the attached picture and have very little idea about how your system works. I am gathering that the circled orifice, which you say is eccentric, is used to control firing of fuel gas into the reboiler (which I assume is the fired heater to the right of the reboiler return line). I can't tell which line flows to the reboiler, but that might not be very pertinent.
Sorry to disappoint you further, but I really cannot answer your question. Measuring a pressure drop across an orifice plate will not ordinarily give you any information about vapor/liquid ratios. However, your control scheme is very likely effective despite this. If you feed the reboiler from a pump, which I assume is the case, then your flowrate is likely nearly constant. The amount of vaporization that occurs will result in very large variations of your volumetric flowrate since the vapor volume will greatly exceed the liquid volume. If fact, for any significant degree of vaporization, the contribution due to liquid flow will be negligable. Thus the dP you measure will correlate to the vapor flowrate under the simplistic system I have described. Again, with the total (mass) flowrate fixed, the vapor flowrate is used to infer the degree of vaporization. Not enough? Fire the heater harder. Too much and you should reduce the heat input.
