I am trying to find height of a cooling tower using my experimental results. From analyzed results, I have values for HTU and NTU which gives me height of tower used in lab. I am supposed to use either of these (HTU or NTU) values and superficial air velocity from my experimental results to scale up and find the height and diameter of cooling tower for higher flow rate. Can you suggest me which parameter should be used for scale up and why? Also is there a specific way to define optimum HTU or NTU? Thanks in advance.
Finding Height Of A Cooling Tower (Scale Up)
Started by cflzif, Sep 21 2011 04:55 PM
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Ll Extraction TowerStarted by Guest_dpunnn_* , 22 Nov 2024 |
Flash Tower With Tray In Deoiling Of Wax?Started by Guest_AnbIran_* , 01 Jul 2024 |
![]() Absorber Tower Can't Be ConvergedStarted by Guest_dynamichysys_* , 14 Jun 2024 |
