Tso Requirement For Shutdown Valves
Started by ogpprocessing, Sep 22 2011 02:04 PM
Posted 22 September 2011 - 02:04 PM
Dears,
What is the criteria for consideration of TSO (Tight Shut Off) Requirement for SDV or ESDV?
Posted 23 September 2011 - 10:58 AM
Dears,
Ogpprocessing,
Safety issues!
In case of emergency shutdown any leakage through the ESDV or SDV may result in development of likely catastrophic conditions in its downstream.
Fallah
Posted 23 September 2011 - 11:24 AM
Dears,
Ogpprocessing,
Safety issues!
Fallah
I know about the importance. I did mean for which cases this TSO should be specified for ESDV/SDV?
Posted 25 September 2011 - 01:42 AM
ogpprocessing,
I am wondering! You did want the reason, and i submitted it: Safety issues.
Anyway, almost all ESDV/SDV should have TSO characteristics.
Fallah
![]() Breather Valves - Liquid Movement In Breathing ScenarioStarted by Guest_panoska_* , 14 Dec 2024 |
![]() Isolation Requirement For Bypass Valves/ Movs.Started by Guest_shantanu.ghag_* , 15 Sep 2024 |
Logic For Start Up And Shutdown Of Hp CompressorStarted by Guest_umeshgps_* , 17 Aug 2024 |
![]() Pressure Regulators Vs Control ValvesStarted by Guest_panoska_* , 19 Jun 2024 |
Nitrogen RequirementStarted by Guest_Ali4269278331_* , 05 Jun 2024 |
