Posted 24 September 2011 - 03:02 AM
I am particularly confused about the temperature at which it is referred?
Posted 24 September 2011 - 03:30 AM
Check this out:
http://www.cheresour...fic-gravity-sg/
http://en.wikipedia....pecific_gravity
http://en.citizendiu...wiki/Hydrometer
Posted 24 September 2011 - 06:31 AM
Vibhs,
Check this out:
Thnx Ankur Srivastava Sir for your reply.
But still the term remain confusing to me. If I go by the definition of
http://en.citizendiu...wiki/Hydrometer, then Specific gravity of water should always be 1.0 irrespective of temperature, which is not the case. Can You put some more light on this.
Vibhs
Posted 24 September 2011 - 08:00 AM
The citizendium article considers a reference temperature of 4 deg C for specific gravity measuremets. At 4 deg C water has its maximum density of 1000 kg/m3 and thus its specific gravity is equal to 1 at the reference of 4 / 4 deg C. At temperatures below 4 the density off water decreases and thus the specific gravity also decreases (remember ice floats on water). As the temperature increases above 4 deg C the density of water again starts to decrease and for a sample of water at 30 degC the specific gravity would be
Specific gravity at 30 deg C = Density of water at 30 deg C / Density of water at 4 deg C
Sp. gravity @30degC = 995.65 / 1000 = 0.99565
Hope this is clear now.
Edited by ankur2061, 24 September 2011 - 08:00 AM.
Posted 24 September 2011 - 01:33 PM
When you are working with gases the SG is the ratio of the molecular weight of the gas to the molecular weight of dry air. This is not a universal rule, but I would say it is overwhelmingly the most used definition for gas SG. The gas SG is most usually used in valve sizing equations. The equation is then set up for air and the SG is used as a correction factor. The base equation (eg Fisher) will be set up for air at a "standard" temperature and pressure and there will also be corrections in the equation for the actual temperature and pressure. You will find lots of people argue against this definition, but as I say - it is the one that I have always seen in the literature.
Posted 24 September 2011 - 03:59 PM
http://www.cheresour...h__1#entry44481.
Edited by kkala, 24 September 2011 - 04:02 PM.
Posted 25 September 2011 - 11:13 PM
Posted 30 September 2011 - 04:39 AM
Though an apparently simple concept, it is surprising to see how often the meaning and the measurements are misunderstood and misapplied.
Posted 30 September 2011 - 08:53 AM
English definition of specific gravity is just the relative density of the liquid to water, or the relative density of the gas to air (then the question "under what conditions" is arisen).
All these have been discussed in the mentioned threads of the past, if someone is interested.
![]() Gravity Flow Between 2 Atmospheric Vented LocationsStarted by Guest_ChemEngrr_* , 19 Aug 2021 |
Monoethanolamine Specific Heat Function Of TemperatureStarted by Guest_Lila54_* , 29 Dec 2020 |
![]() Sizing Tank Overflow Line For Gravity FlowStarted by Guest_pxyarala_* , 05 Nov 2020 |
